Thread: 130 pd awx coolant temp low
Results 1 to 1 of 1
  1. 130 pd awx coolant problems -help
    Jan 2006
    Near Basingstoke
    after earlier post I used VCDS to ascertain that coolant temp was slightly low at 83 degrees. Was going to get round to changing stat when the weather warmed up but since then have noticed that there is a slight coolant leak from somewhere (looses a little bit of coolant over 1K miles) and that the temp sensor was changed a few K miles before I bought it.
    If there is a leak somehwere would this cause the system to not presurise proberly and if so drop the temp (I vauguely remember something about temp, pressure and Boyles law in Physics or should I just change the thermostat. Could the new temp sensor be faulty and if so would it be giving the ECU a bum steer?
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. Lupo temp coolant light + brown coolant
    By andyt67 in forum Polo - Derby - Lupo - Fox
    Last Post: 02-05-2009, 09:52 AM
  3. Coolant temp guage
    By mowjoe in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2009, 08:00 PM
  4. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  5. What is the safest way to dispose of old G12 Coolant ?
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 13-04-2008, 03:38 PM
