Thread: VW Golf MK3 Diagnostic Socket
  1. VW Golf MK3 Diagnostic Socket
    May 2006
    Please could anyone help, I have tried to connect a 'Creader V' to my Golf to read the error codes. The reader cannot keeps sending the message 'cannot connect'. I have put a voltage meter on pins 16 and 7, pin 16 give 12volts which appears to be correct, but pin 7 (K-line pin) does NOT show any voltage reading at all. I think pin 7 should show between 2-3 volts.
    Any ides what the problem may be ?
  2. Re: VW Golf MK3 Diagnostic Socket
    131 Post(s)
    1973 Post(s)
    Problems with the OBD II socket are very rare, I would suspect the problem lies with your code reader as the Creader V is for OBDII compliant vehicles and your car is not OBDII or EOBD compliant. Pin 16 is permanent live, pin 4 is earth, pins 15 and 7 go to the diagnostic junction box as a two pin plug.
  3. Re: VW Golf MK3 Diagnostic Socket
    May 2006
    Thanks for your answer, you say my vehicle is NOT OBDII or EOBD, then what is the 16 pin diagnostic plug for ?. I have seen on ebay VAG 405 scanners, do you think they would work on my car ?
  4. Re: VW Golf MK3 Diagnostic Socket
    131 Post(s)
    1973 Post(s)
    The socket is an OBDII type but the cars ECU and software is not OBDII. No UK Golf 3 was ever OBDII. I only use VCDS so I cannot comment on other systems which will work on your car like VCDS does.
  5. Re: VW Golf MK3 Diagnostic Socket
    Oct 2011
    uk
    thanks for all the info there can someone tell me if the VAG-COM cable with USB connector for 409.1 will work on a vw golf mk3
  6. Re: VW Golf MK3 Diagnostic Socket
    131 Post(s)
    1973 Post(s)
    Yes, reasonably well.
  1. Please Help vw golf mk3 1.8 1993 rocker cover
    By mohammad in forum Golf MK3 - 1993 - 1999
    Last Post: 03-08-2010, 07:36 PM
  2. New member '98 VW Golf Mk3 1.6A AFT engine
    By ski808 in forum New Member Introductions
    Last Post: 13-09-2007, 11:40 PM
