Thread: Fitting DAB Radio in A8 2005
  1. Fitting DAB Radio in A8 2005
    Sep 2014
    Bristol, United Kingdom, United Kingdom
    Hi all,
    I have bought myself a lovely A8 2005 3.0tdi.I would like to fit DAB. I have a few questions please.
    1. I have the pop up colour SATNAV so does that mean I have MMI -G2?? .....
    2. I believe I need Audi Q7, A6, A4,A5,A8, MMI 2G DAB RADIO WITH PLUG&PLAY WIRING 4E0910563C | eBay ??
    3. Are there any instructions for fitment available???
    Cheers....Neil
  2. Re: Fitting DAB Radio in A8 2005
    Sep 2011
    Lurking over a keyboard ...
    Yes you have MMI 2G, I think that item is correct will double check in EPC.
    Regards
    G
  3. Re: Fitting DAB Radio in A8 2005
    Nov 2009
    46 Post(s)
    Tis correct one, a friends 2008 A8 uses the same control module for 2G.
  4. Re: Fitting DAB Radio in A8 2005
    Sep 2014
    Quote Originally Posted by gupsterg View Post
    Regards
    G
    Thank you for the info....just need to find a cheaper kit now if poss..Neil
  5. Re: Fitting DAB Radio in A8 2005
    Sep 2014
    Thank you ....Regards Neil
  6. Re: Fitting DAB Radio in A8 2005
    Dec 2008
    Stoke-on-Trent
    Have a look on ebay in Germany, that's where I bought mine from, paid about £110 delivered. you should be able to get the fibre and power cable set for about £45 - £50
  7. Re: Fitting DAB Radio in A8 2005
    Sep 2011
    Hi Neil,
    MMI modules have usually 2 part no:-
    Software: 4E0 910 563 C
    Hardware: 4E0 035 563
    Search both for greater results, with & without spaces, the C rev SW is the latest.
    Link:- This german ebayer was where I got mine Link:- This was the cheapest cable set I found
    For the fibre optical cable you will have to do some of your own dismantling/assembly as this is not the one which is already configured. On the fibre optical plugs is an arrow denoting data in/out as the MOST loop works in series you will be creating another loop in it.
    Link:- This one is fully plug and play
    Plus you'd still need the DAB aerial, quick view of EPC shows that aerial unit fitted above the rear windscreen will not have DAB aerial as yours did not come with it from factory.
  8. Re: Fitting DAB Radio in A8 2005
    Sep 2014
    Hi all,
    I have now got the DAB Module and plug and play leads....but I can not find any instructions for fitting the module, or rather which leads to fit where?? someone has said it is "straight forward" but I would sooner see some instruction first...can anyone help please!!?
    Neil
  9. Re: Fitting DAB Radio in A8 2005
    Sep 2014
    I have the module and wiring kit now, you have mentioned I would not have the "aerial unit fitted above the rear windscreen"....do you mean the Aerial amplifier, I have one coming...hopefully... or do I need something else as well!!?
    Regards Neil
  1. dab radio
    By gadgee in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 08-05-2014, 02:22 PM
  2. 2005 A8 W12, DAB radio/Freeview TV upgrade?
    By frankA6 in forum A8 - S8 - V8
    Last Post: 05-06-2011, 12:18 PM
  3. 2005 A8 W12, DAB/Freeview upgrade?
    By frankA6 in forum In Car Entertainment
    Last Post: 05-06-2011, 10:42 AM
  4. Retro Fitting DAB
    By SpinneyA6 in forum In Car Entertainment
    Last Post: 17-10-2010, 10:20 AM
  5. DAB aerial fitting
    By jam in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 06:31 PM
