Thread: MMI 2g 5570 update & hidden menu
Results 11 to 20 of 34
  1. Re: MMI 2g 5570 update & hidden menu
    Mar 2009
    Helsingborg, Sweden
    Thanks AndyB
    If it would just stop raining I can go out and get on with things!! Just one thing though; if a constant voltage should be maintained, is it better to have the battery on charge because if the engine is running for a long time is there a danger that the electric fan will come on and cause a big drop?
    Is it ok to just use discs 1 & 3 so as to protesct the BT module?
    I'm finding this process a bit scary
  2. Re: MMI 2g 5570 update & hidden menu
    Nov 2010
    Watford
    Hi Piotrek,
    The 3cd's for MMi high update (4L0 998 961) are for the updating of MMi high to the latest version 55.7.0
    The one DVD for navigation update, updates the digital road maps data and language base. When I updated the MMi to version 55.7.0 I had already purchased the 2010 Nav DVD, it's possible you need a newer Nav DVD to enable the 3D view to work (unsure).
    You have the cd's you need to perform the update of all components connected to the MMi.
    I'm afraid your dealer 'might not' be correct.
  3. Re: MMI 2g 5570 update & hidden menu
    Sep 2010
    Bristol, UK
    From what I have learned here on the forum you can do the update while driving, as I did on my way to and back from work, stationary with the engine running or stationary with a battery charger connected. Just make certain enough power is maintained to the MMI.
    If you use a battery charger make sure you connect to the charging points otherwise the battery manager/ monitoring may not pick up the charge just the drain!
    When I updated I had just replaced the BT module (front seat out job!) as it had failed so I only used discs 1 & 3 without issue.
    Nothing to be scared about, but that's easy to say after I've had a problem free update...
    BTW I sent you an email....
    AndyB
    Current: 2009 Q7 S-line 240 PS 3.0l TDi
    Gone but not forgotten: 2006 '06 Audi S6 5.2 V10 Quattro
  4. Re: MMI 2g 5570 update & hidden menu
    Nov 2010
    Watford
    Priotrek,
    I also felt nervous about the update but not as scared as that blue face!
    I guess if you are going to update the MMi you just need to go for it.
    As I have said I left the engine running and had no problem. Originally I was going to use a charger but everyone else just left the car running so that is what I did.
    See no reason why you can't run the update without disc 2. If your version is 51.5.0 you only need then use disc 3.
    If you have had no problem with bluetooth/telephone module then any bugs it might have are not a problem to you.
    We are all rooting for you now.
    Looking forward to the "I'VE DONE IT" post.
  5. Re: MMI 2g 5570 update & hidden menu
    Jan 2010
    Chobham, Surrey
    Your dealer is right, and wrong.
    Every map DVD also has a navigation (only) firmware 'update'* on it. But it won't update the MMI itself.
    * and it isn't really an update. If for example you go back from, say, 2009 maps to 2006, it will still 'update' the navigation.
    Golf GT 140 TDI. Mods: RNS510
  6. Re: MMI 2g 5570 update & hidden menu
    Mar 2009
    Helsingborg, Sweden
    Hi guys
    So I ran the updates and came through but not without some headaches. I put a posting on earlier today where A8 gave me some quick and very helpful advice, however having now done a VCDS autoscan it's found some errors, particularly that it can't find the Control Head - module 7 !!!! This wasn't a problem b4 the update, also the language of the factory installed phone has changed to German!
    There is also - can't find ABS, and a few others. Have also enabled the hidden menu to try and see the battery meter & oil level but I don't see them at all!!
    So can anyone give me a clue please.
    PS - I can see the SW is now 5570
  7. Re: MMI 2g 5570 update & hidden menu
    #17
    Feb 2013
    Manchester
    Quote Originally Posted by sparker View Post
    I ran the update cd's on my car with a reversing camera and didn't have any problem with it or anything else, only the battery meter went (don't really miss it). The update doesn't make any dramatic difference to the way anything in the car works, nice to have a 3D option for the sat-nav but that is all I noticed. The main reason to update I guess is for bluetooth updates to run newer phones. Gave me a cold sweat running the cd's, worrying about what problems I might be creating in my computer runs everything car. For me all went well and I think that is the case for most people but I have read a fair amount of horror story's too.
    Get as much info as you can before you start (some times you need to run a cd twice to make it work). Follow the instructions (my instructions came from Boston Audi too). I left the car running. I'm sure you will be fine.
    Hi Pete
    Where can i find a copy of these instructions? Thanks : )
  8. Re: MMI 2g 5570 update & hidden menu
    #18
    Nov 2010
    Watford
    Quote Originally Posted by abdulr001 View Post
    Hi Pete
    I haven't got the Boston Audi instructions on line but this is a better instruction leaflet to follow;
    Take a look at this link from Gupsterg. Ignore the first part but the rest explains the process of updating and is a helpful read. It does remove the battery meter from your MMi (easy to put back on with VCDS). Some people have problem with the phone module but most times all seems fine. Mine worked OK.
    http://uberlame.com/a6_tsb/Electrica...%20%282%29.pdf
    Hope that is what you are looking for.
    Audi Allroad 3.0tdi. Tiptronic. 12/12/2006. Full Phantom Black, 19" alloys, MMI high, Navigation, Phone prep, Heated sports seats with memory, Parking advanced with rear camera, Sunroof, Rear blinds.
  9. Re: MMI 2g 5570 update & hidden menu
    #19
    Feb 2013
    Manchester
    Thanks for that. I was going to attempt this with the engine running, or is it better with the car on charger? How does this work, just put the key in and turn till mmi comes on without actually starting the car?
    Also, i have been told by the Audi specialist who provided the discs, not to bother with disc 2 if i have bluetooth, just to use disc 1 followed by disc 3. I am on a 2120 system.
    Thanks again
  10. Re: MMI 2g 5570 update & hidden menu
    #20
    Sep 2011
    Lurking over a keyboard ...
    If you have bluetooth run disc 2 twice, so you would be doing disc 1 once, disc 2 twice, disc 3 once...
    If you do not have bluetooth you would be doing disc 1 once, disc 3 once...
    I did mine with a recharger on the slave points in the engine bay (ref your owners manual) or Link:- MMI 2G Hi Update. Any issues?
    People have done it with the engine running but I'm not a fan of that as when flashing you really don't want voltage variance,etc...
    Empty CD changer use slot one... the MMI FW update will only update what needs to be updated... ref the screenshots in the PDF above...
    Regards
    G
  1. MMI Update - What am I doing wrong / missing?
    By ukandyb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-03-2011, 11:37 AM
  2. Accessing hidden menu on MY2010 3G MMI
    By MFGF in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-09-2010, 07:55 PM
  3. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
  4. The performance SUV Audi Q7
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
