Thread: heaters
  1. heaters
    Oct 2010
    Greenock,Scotland
    Hello iam hoping someone can help me,i was out in car today and weather was really nice so i turned down both heaters as low as they can go and noticed a few minutes later that only drivers side two vents were blowing out really cold air,the passenger side two vents were blowing hot air out so i turned passenger side temperature right up and it stays the same temperature warm as if its stuck on a certain temp at this side display still goes up and down but with no change in temperature,has anyone had this problem?if so how did they fix it,car was fine until today.
    its going to be a bad summer if ive got heaters stuck on(on one side)
  2. Re: heaters
    Southern County Softy
    20 Post(s)
    air distribution flaps can stick.
    Take the glovebox out and look at the motors and arms while changing sattins on the control panel.
    Use the search button, this has been discussed a few times...
    A4 2.5 tdi QS (mapped)
  3. Re: heaters
    Oct 2010
    Greenock,Scotland
    Thank you Kite all working again now red lever was stuck freed of and lubed all working fine now,and it was good to see wot all the other mechanics do when i push certain buttons so if the others brek i will know where to look now
    10minutes to do easy
  1. Please Help A3 1.6 1998 overheating/cold heaters!
    By Prey in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-02-2011, 04:01 PM
  2. Heaters seem a little slow to warm up
    By Sloppy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-01-2011, 08:22 PM
  3. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  4. Heaters Blowing Cold air! Head gasket or Heater Valve?
    By yellow-160 in forum Golf MK2 - 1984 - 1992
    Last Post: 08-06-2008, 04:29 PM
  5. Rear seat heaters warmers not working
    By patrick in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-11-2006, 05:09 AM
