Thread: Fabia 1.2 Misfire at idle
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Fabia 1.2 Misfire at idle
    May 2012
    Belfast
    Cheers zenman,
    I had narrowed it down to the second cylinder miss firing because of a sticky valve but have been trying to avoid taking the head off.
    I have flushed the whole engine (engine and new oil) and have been running forte engine flush thought it on BP premium petrol. The forte stuff used to fix the sticky valves on the Zetec engine.
    The problem seems to be getting worse now with the forte but I only hope this is the stuff working, removing the carbon stuck on the valves.
    I still have another tank to run through the engine and then if no better then the head has to come off.
    I am lucky enough to know a mechanic who said he would replace the valves for Ł360. That is take the head off, 4 new valves, skim head, all back together.
    It was his mate a got the car off so feels a bit responsible I think.
    Will let you know how it gets fixed!
    Thanks guys for your helps.
  2. Re: Fabia 1.2 Misfire at idle
    133 Post(s)
    1986 Post(s)
    3 new valves, not 4. It will be a burnt valve with a worn guide so you will have to replace the exhaust guides as well, if you don't the new valve will fail again in around 20K miles.
  3. Re: Fabia 1.2 Misfire at idle
    May 2012
    Belfast
    I was going to replace all the values on cylinder 2. So 4 values per cylinder (12 valve). As cylinder 2 is the only problem (thinking about it, may only do the 2 exhaust valves now).
    I have heard that it is heat not getting away from cylinder 2 that causes this carbon build up, so cylinder 1 and 3 are usually fine.
    I hadn't thought about replacing the valve guides, I am only doing this to sell the car as it is sitting doing nothing.
    Thanks.
  4. Re: Fabia 1.2 Misfire at idle
    133 Post(s)
    1986 Post(s)
    Quote Originally Posted by paulstewart View Post
    Of the last four we have done that I can remember, one had a number 1 failure, one failed on number 2 and one failed on number 3 so that shoots that theory down in flames! If anything, number 3 will run hotter on the 12 valve due to the EGR valve port being there.
    1 on 1
    1 on 2
    2 on 3
    Oct 2010
    Here And There
    Thats only 3 lol
  6. Re: Fabia 1.2 Misfire at idle
    133 Post(s)
    1986 Post(s)
    Doh! I was editing it so that the car was alpha and the cylinder number numerical and I cocked it up!
    Oct 2010
    Here And There
    lol
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Question Vw passat 2001 TDI sport 130 BHP..high on fuel consumption
    By kingmuff in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2011, 10:07 AM
  3. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  4. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
