Thread: Fabia 1.2 Misfire at idle
Results 1 to 10 of 17
  1. Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    I have a Fabia 1.2 (40kw) with detectable missfire on the center cylinder, but only at idle. Fault code p0202 circuit defective sporadic comes up on the Bosch KTS 540 and I can see the missfires being counted in live data.
    One step at a time I:
    Swapped 1 & 2 spark plugs
    Swapped injectors
    Swapped coil packs.
    Misfire is still on the middle cylinder.
    Anyone come accross this before?
    I have to leave it now, but I plan on scoping the injector switching (amps and volts), then doing a compression check. tomorrow (Sunday) or later in the week.
    Cheers for any help or ideas.
    I'll check here before I start with the spanners!
    Oct 2010
    Here And There
    mmm
  3. Re: Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    Update
    I have removed the ECU, checked the continuity of the injector earth (switched side to ECU) OK.
    Cleaned up the contacts and refitted the ECU (it was out for 4 days until I obtained some contact cleaner spray).
    Guess what.... Its now worse than ever.
    Different fault code now.
    injector faulty, but its not..., because I swapped it with one of the others.
    I'm going to check compression, then cross over the wires from Inj 1 - 2.
    I'll keep you posted (it takes me a week to get motivated) teenagers!
    Oct 2010
    Here And There
  5. Re: Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    Cheers,
    It's bit more serious than that, I have diagnosed that the ECU is not switching number 2 injector. I will do that if it detects a missfire.
    Electrics OK.
    Compression test showed -
    11bar Number 1 cylinder
    7 bar Number 2
    12 bar number 3
    Cylinder leak test was inconclusive, so it's engine out today.
    I only want to remove the cylinder head, but to remove the timing chain I will have to remove the sump.
    A bit more work than I wanted, but it has to be right.
    Selected photos and before and after test results will be posted, (as soon as I get time).
  6. Re: Fabia 1.2 Misfire at idle
    May 2012
    Belfast
    I am having exactly the same problem with a 1.2 Skoda Fabia.
    Did you ever get this problem sorted?
    Would appreciate any advise as trying to get this problem fixed at the minute.
    Thanks,
    Paul
  7. Re: Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    You might not want to hear this!
    New exhaust valves sorted it, a compression test showed number 3 to be down by about 20%, the ECU stops delivering fuel to the injector.
    The golden rule is: always check the mechanics before the electrics!
    I took the engine out to do the valves, but you don't need to. I did make a tool to remove the valve springs and a tool to position the camshaft on reassembly, and I used VW liquid gasket on the rebuild. A big job but quite simple. Timing chain drives the counter balance shaft, with a position mark.
    I'm glad it was that, cos I'd checked EVERYTHING else!
    Good luck, PS Someone who worked at VW said this engine is a bit prone to this fault.
    D
  8. Re: Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    Sorry, should read number 2 cylinder, thinking about a Vauxhall!
  9. Re: Fabia 1.2 Misfire at idle
    133 Post(s)
    1986 Post(s)
    Quote Originally Posted by zenman View Post
    All you have diagnosed there is the ECU doing is EU4 job, when the ECU detects an emissions problem it identifies the offending cylinder and shuts off the injector. You have low compression on that cylinder and the head will have to come off for a rebuild with new exhaust valves and guides, this is becoming meat and two veg work for the garagre trade on the VAG 3 cylinder 1.2 engine, especially the 6 valve version.
    I can see you have done this but for anyone else with a 3 cylinder petrol and a misfire, before wasting any time, get a compression test done.
  10. Re: Fabia 1.2 Misfire at idle
    Apr 2011
    Lancaster
    As I said "The golden rule is: always check the mechanics before the electrics!"
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Question Vw passat 2001 TDI sport 130 BHP..high on fuel consumption
    By kingmuff in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-04-2011, 10:07 AM
  3. Tune Weber carb (not type specific)
    By bishbosh66 in forum Volkswagen
    Last Post: 30-01-2008, 11:34 AM
  4. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
