Thread: Front Window dropped into Door
Results 1 to 9 of 9
  1. Front Window dropped into Door
    Oct 2006
    I have found much helpful info on this problem but a question arises.....
    On our Mk4 Golf 1.6se, with electric windows, the driver side front window has today dropped into the door and won't rise. From what I read it sounds like the clips have failed. With genuine kit costing around £50 and pattern parts (just the clips) around £17, will I need the full kit?
    Will be looking this afternoon to see what has happened cos we need to get the glass up for security and weather reasons, but any comments will be appreciated....Can I jam the glass up temporarily?
    This thread
    http://forums.vwvortex.com/showthrea...or-lock-module
    makes it look quite daunting but others are saying an hour or so to sort
    Comments please
  2. Re: Front Window dropped into Door
    Feb 2010
    Sheffield
    I had this same problem with mine, both the drivers side and passenger side went within a couple of weeks of each other.
    I would recommend getting the full window regulator kit, if i remember rightly they cost £42 from a VW dealer.
    Pretty simple job as well to do, anyone with a bit of common sense and general car knowledge will be able to complete both within an hour, alot of forums have step by step instructions on how to replace them.
  3. Re: Front Window dropped into Door
    Oct 2006
    Thanks for that. What did you do with the door lock module? Did you drill out the rivets and then replace them? Are the rivets part of the kit?
  4. Re: Front Window dropped into Door
    Feb 2010
    Sheffield
    you dont need to drill out the lock that stays where it is and everything can move round it.
    i will have a look for the step by step instructions i used and post the link for you
  5. Re: Front Window dropped into Door
    Feb 2010
    Sheffield
    Here's the link I used, as you go through it step by step it will all make sense.
    You can take it all out with the lock attached to the door part that comes away.
    http://vwgolfr32.co.uk/windowregulator/
    The new clips that come with the kit are metal with a small plastic section, this is because the old 'all plastic' clips broke too easily.
    Good luck
  6. Re: Front Window dropped into Door
    Southampton, UK.
    Thanks for sharing that. A really useful howto.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 Avant 2.0 TDI ultra 190
  7. Re: Front Window dropped into Door
    Oct 2006
    Trying to load a picture of a spring i found in the door when i got the door panel off, bit like a spring from a wooden clothes peg with one leg longer than the other, about 40mm long. Where does it come from? ...and why cant i load an image from photobucket??
  8. Re: Front Window dropped into Door
    Oct 2006
  9. Re: Front Window dropped into Door
    135 Post(s)
    2026 Post(s)
    Quote Originally Posted by sheffieldGTTDI View Post
    If you can strip, fit a repair kit and rebuild two doors in an hour I would love to see you do that. It takes me an hour and a half to do one side!
  1. Replies: 8
    Last Post: 09-11-2009, 04:49 PM
  2. How To remove inner door card and get to lock
    By adzul in forum Golf MK4 - 1999 - 2004
    Last Post: 26-05-2009, 01:58 AM
  3. "How To" Remove door cards from MK3 Golf
    By nathandjmillard in forum Volkswagen
    Last Post: 23-05-2009, 09:00 AM
  4. How does the Quattro system work?
