Thread: VAG COM and Vista. Correct lead and s/w version plz
Results 1 to 10 of 10
  1. Exclamation VAG COM and Vista. Correct lead and s/w version plz
    Mar 2007
    Greater Manchester
    Just wanted to know whats the correct lead to purchase and also correct version of VAG Com to download when using Vista. I previously bought a USB cable from autonostix.com. It didn't seem to work too well.
    Is the serial lead any better than USB?
    Links to places/ppl selling correct leads would be preferable.
    london/ UK
    Have you tried www.ross-tech.com website ? They are selling their own interfaces that will work best with their own program !
    Mar 2007
    Greater Manchester
    Quote Originally Posted by adamss24 View Post
    Thanks for the reply. I'm aware of RossTech but their interface leads appear to be quite pricey. I need a USB (laptop dosn't have Serial Port) and it has to be either Hex, Key or Micro-Can.
    Was hoping somebody could point me in a cheaper direction and some feedback on purchasing and using lead from supplier other than RossTech
    london/ UK
    With your previous interface, did you try to lover the baud rate ? Ussualy the newer laptops are too fast compared with the car's ECU thar will speak an slow Kwp 2000 protocol ! Read the user manual on the resstech website and see if its improves.
  5. Re: VAG COM and Vista. Correct lead and s/w version plz
    Bristol
    dude i think this lead will work ?
    also very useful info on here , im just going to get it all for my sharan ,
    http://www.virtualvillage.co.uk/Items/007551-001
  6. Re: VAG COM and Vista. Correct lead and s/w version plz
    Feb 2007
    wicklow, Ireland
    I bought a vag-com USB cable off ebay... worked a couple of times then gave up the ghost. got it replaced by seller then it failed again after about 5 months (4 days ago) . next time I'll get official ross-tech cable I think!
    It looked like a quality made cable... but...
  7. Re: VAG COM and Vista. Correct lead and s/w version plz
    North Lincolnshire
    Just buy a proper Ross Tech cable. You get what you pay for. I tried a cheapo fleabay version but they only work with the old software version and are very limited.
    The "others" are cheap for a reason. Try Derek at ilexa.com
  8. Re: VAG COM and Vista. Correct lead and s/w version plz
    May 2008
    I have a lead that looks identical to the one on virtualvillage, vista automatically installed the drivers from windows update for it ok. its not compatable with the new versions of vag com only 409.1 or earlier. to run that on vista is a bit hit and miss from what i've read, you need to run it in XP compatability mode and with administrator rights. Having said that i cant get it to find my A4. Its a 97 A4 avant 1.8T but neither vag com or my friends memoscan U581 obdII reader can find the car? anyone any ideas? as far as I can tell the U581 works with audi's and it works with my friends 1.8t golf. Is my car OBD compatable?
  9. Re: VAG COM and Vista. Correct lead and s/w version plz
    North Lincolnshire
    Quote Originally Posted by ShuMart View Post
    Do you have an aftermarket radio ? if so, check out www.ross-tech.com and search for "aftermarket radio problem"
  10. Re: VAG COM and Vista. Correct lead and s/w version plz
    May 2008
    Nah I have the standard Audi Conert radio fitted
  1. Correct version VAG-Com to download
    By jollybodger in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-07-2007, 08:44 PM
  2. Allroad 155ps version?
    By pdk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2007, 10:51 PM
  3. Which version of vag com should i be looking for?
    By Eshrules in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-05-2007, 12:53 PM
  4. Vagcom freeware Vs full version
    By stormtrooper in forum VCDS - General Questions
    Last Post: 17-04-2007, 08:25 PM
  5. Windows Vista
    By Foxcub in forum VCDS - General Questions
    Last Post: 10-04-2007, 10:50 AM
