I am trying to tackle few faults and this one should be fairly straightforward.
The following code appeared, and I have been trying to find correct part number.
Address 01: Engine Labels: None
Part No SW: 4E0 910 402 B HW: 4E0 907 401 D
Component: 3.0L V6TDI G000AG 0030
Revision: --H03--- Serial number: AUX3Z0F2388347
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 1B3E529AA3CD
1 Fault Found:
006256 - Transmission Mount Valve 1 (N262): Open Circuit
P1870 - 001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 260417 km
Time Indication: 0
Date: 2011.03.19
Time: 11:24:02
Freeze Frame:
RPM: 882 /min
Torque: 85.8 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 13.91 V
Bin. Bits: 00001000
Torque: 234.0 Nm
Readiness: 0 0 0 0 0
Ignore the frequency as it has been just past the reset.
I have searched for part number and I am not sure if I have correct part no and whether I need left mount or right mount.
4E0 199 381 FH - left Hydro mount (electric)
4E0 199 381 FJ - right Hydro mount electric.
My build is 4e8 06l Engine code ASB and gearbox is JAY.
Car does have some vibration at idle so I presume it is shot. Any other mounts that might need looking at?
Any ideas?
Tom
