Thread: A4 Cabriolet Roof Fault?
Results 1 to 8 of 8
  1. A4 Cabriolet Roof Fault?
    Feb 2010
    Coventry UK
    57 MY A4 Cab.
    Got a slight problem with my roof: Opens at front a few inches then stops (roof fault light flashes) if I close it down and re-attempt to open it usually works ok.
    This happens every time I try to open the roof (except when it has been recently opened, say within a few hours)
    Anyone know if there is an oil reservoir (if so where?) or where the position sensors are located ?
    many thanks in advance, Malo
  2. Re: A4 Cabriolet Roof Fault?
    Southern County Softy
    20 Post(s)
    Scan the car for faults.
    A4 2.5 tdi QS (mapped)
  3. Re: A4 Cabriolet Roof Fault?
    131 Post(s)
    1974 Post(s)
    Try using the emergency key to fold the roof all the way down, lock the rear panel down and then fold the roof back up, then try running it again. If this fails you will need a code read. I have one coming in tomorrow that does something similar but no warning light or fault codes. I have ordered a new pump motor for it as the pump will not run with power directly applied. The pump and reservoir are located under the floor level in the boot tucked away down in the right hand rear corner, a right sod to get at.
  4. Re: A4 Cabriolet Roof Fault?
    Aug 2013
    Hitchin, Herts
    I know this is an old thread but just in case it helps anyone else I had a similar fault and had it cured by having the hydraulic pump motor overhauled. This was by Autoelectron via Ebay:
    http://myworld.ebay.co.uk/autoelectron
    The service was excellent, very helpful on the phone and very quick turnaround. Total cost less than £100 vs. £1500 quoted by Audi.
  5. Re: A4 Cabriolet Roof Fault?
    131 Post(s)
    1974 Post(s)
    Audi misquoted you, the motor is only £200 and there is no way on Gods earth they overhauled the pump complete unit for <£100, that only just buys you a motor re-brush...
  6. Re: A4 Cabriolet Roof Fault?
    Aug 2013
    Hitchin, Herts
    Apparently, Audi only supply the complete motor and pump assembly and with fitting they quoted me £1500. I only had the motor done, maybe "overhaul" is the wrong terminology but it worked in my case and just trying to help anyone else.
  7. Re: A4 Cabriolet Roof Fault?
    131 Post(s)
    1974 Post(s)
    The three I have bought in the last year must have been in my imagination....
    Item 2, part number 8H0 959 755 A £203.41 inc. VAT from any Audi dealer, fits all Audi A4 cabriolet 2003>2009.
    The pump itself is not available as a spare part.
  8. Re: A4 Cabriolet Roof Fault?
    Aug 2013
    Hitchin, Herts
    Well, I can assure you that the £1500 quote from Audi was not my imagination. OK, it may not be comparing like with like but at the end of the day, I just wanted my roof fixed and that is what they wanted to do it.
    Just trying to provide the information in case it helps anyone else is in a similar predicament and give credit where it is due.
  1. Retrofitted RNS-510, Changed GW, now a lot of errors
    By bjuran in forum VCDS - Help Requests
    Last Post: 09-07-2011, 01:37 PM
  2. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  3. dpf fault
    By deutsch in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2010, 02:50 PM
  4. 05 Audi A4 2.0 TDI problems
    By Dent Reform in forum VCDS - General Questions
    Last Post: 12-05-2008, 09:18 PM
  5. Can I fit Satnav to my new A4 Cab
    By car@fmcneill.fr in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-04-2008, 10:09 AM
