Thread: A3 1.9tdi cutting out over bumps - HELP!!
Results 1 to 9 of 9
  1. A3 1.9tdi cutting out over bumps - HELP!!
    May 2009
    Belfast
    Folks -
    As above - my 2005 Sportback mysteriously judders/cuts out at times - the common denominator being bumps or potholes - happens 90% of the time. It's not a slow loss of power - it's almost like the brake is coming on!
    Anyone got any ideas? Have checked connections for injectors etc and cleaned them but no joy.
  2. Re: A3 1.9tdi cutting out over bumps - HELP!!
    133 Post(s)
    1990 Post(s)
    Any fault codes?
  3. Re: A3 1.9tdi cutting out over bumps - HELP!!
    May 2009
    Belfast
    Cheers buddy!!!
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
    01-Engine -- Status: Sporadic communication error 1000
    15-Airbags -- Status: OK 0000
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door,Rear Left -- Status: Malfunction 0010
    7D-Aux. Heat -- Status: OK 0000
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 016 CC HW: 028 101 183 2
    Component: R4 1,9L EDC 0000SG 6231
    Revision: 12345678 Serial number: AUX7Z0D9FND0BK
    Coding: 0000071
    Shop #: WSC 06314 000 00000
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 N
    Component: ASR FRONT MK70 0103
    Coding: 0017025
    Shop #: WSC 06435 000 00000
    1 Fault Found:
    01314 - Engine Control Module
    Address 08: Auto HVAC Labels: 8P0-820-043.lbl
    Part No SW: 8P0 820 043 D HW: 8P0 820 043 D
    Component: KlimavollautomatH12 0150
    Revision: 105846 Serial number: 8P0820043D
    1 Fault Found:
    00819 - High Pressure Sensor (G65)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 3
    Fault Frequency: 198
    Reset counter: 119
    Mileage: 226825 km
    Time Indication: 0
    Date: 2010.09.18
    Time: 21:59:02
    Freeze Frame:
    Temperature: 4.5°C
    Voltage: 12.10 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
    Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
    Component: Bordnetz-SG H34 0301
    Revision: 00H34000 Serial number: 00000001126281
    Coding: 01884F02B214100000160000160000000000FE0F5C
    Shop #: WSC 00000 000 00000
    Part No: 8P2 955 119 B
    Component: Wischer AU350 H01 0130
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found:
    02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
    00188 - Control Circuit 1; Relay for Supply Voltage Terminal 50
    010 - Open or Short to Plus - Intermittent
    Address 15: Airbags Labels: 8P0-959-655-94.lbl
    Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
    Component: Airbag 9.41 H10 2620
    Revision: 91H10262 Serial number: 00362000RVWF
    Coding: 0033622
    Address 16: Steering wheel Labels: 1K0-953-549.lbl
    Part No SW: 1K0 953 549 HW: 1K0 953 549
    Component: Lenksäulenmodul 012 0030
    Coding: 0000002
    Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
    Part No SW: 8P0 920 900 F HW: 8P0 920 900 F
    Component: KOMBIINSTR. VDO H72 0210
    Revision: D03 Serial number: 1249DD03013973
    Coding: 0004448
    Shop #: WSC 00411 210 03906
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 D HW: 1K0 907 951
    Component: Gateway H08 0100
    Revision: 08 Serial number: 25001049270233
    Coding: 3D3F0B42072103
    2 Faults Found:
    00469 - Infotainment Databus in Single Wire Operation
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 119
    Mileage: 232699 km
    Time Indication: 0
    Date: 2011.02.11
    Time: 17:20:30
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Revision: D03 Serial number: AUX7Z0D9FND0BK
    Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN.lbl
    Part No: 8P0 959 801 E
    Component: Tuersteuerger. H10 0030
    Coding: 0000016
    1 Fault Found:
    00912 - Window Regulator Switch; Front Left (E40)
    008 - Implausible Signal - Intermittent
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.9 1301
    1 Fault Found:
    Freeze Frame:
    Mileage: 3440 km
    Temperature: 20.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Address 46: Central Conv. Labels: 8P0-959-433.lbl
    Part No: 8P0 959 433 E
    Component: KSG H04 0050
    Coding: 188000186D088505489F016000
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 47: Sound System Labels: 8Px-035-382.lbl
    Part No SW: 8P4 035 382 HW: 8P4 035 382
    Component: AB2 SUBWOOFERBOXH02 0160
    Revision: 00001 Serial number: 10000001189590
    Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN.lbl
    Part No: 8P0 959 802 E
    Coding: 0000016
    Address 56: Radio Labels: Redir Fail!
    Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
    Component: concert II EU H51 0100
    Revision: 01S Serial number: AUZ2Z3D1535597
    Coding: 0001001
    Address 62: Door,Rear Left Labels: 8P4-959-801.lbl
    Part No: 8P4 959 801 B
    Component: Tuer-SG H10 0010
    Coding: 0000144
    1 Fault Found:
    00934 - Electric Window Motor; Rear Left (V26)
    005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
    Part No: 8P4 959 802 B
    Coding: 0000144
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
    Component: PTC-Element 0404
    Revision: 00800000 Serial number:
  4. Re: A3 1.9tdi cutting out over bumps - HELP!!
    Jan 2010
    Wakefield, West Yorkshire
    Quote Originally Posted by tates1979 View Post
    Cheers buddy!!!
    Chassis Type: 1K0
    Coding: 0000071
    Coding: 0017025
    1 Fault Found:
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 3
    Reset counter: 119
    Mileage: 226825 km
    Time Indication: 0
    Date: 2010.09.18
    Time: 21:59:02
    Freeze Frame:
    Temperature: 4.5°C
    Voltage: 12.10 V
    RPM: 0 /min
    Load: 0.0 %
    Load: 9.0 %
    Coding: 00062736
    Shop #: WSC 00000
    3 Faults Found:
    Coding: 0033622
    Coding: 0000002
    Coding: 0004448
    2 Faults Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 3
    Reset counter: 119
    Mileage: 232699 km
    Time Indication: 0
    Date: 2011.02.11
    Time: 17:20:30
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    Coding: 0000016
    1 Fault Found:
    1 Fault Found:
    Freeze Frame:
    Mileage: 3440 km
    Temperature: 20.0°C
    Voltage: 12.50 V
    Voltage: 12.30 V
    Coding: 0000016
    Coding: 0001001
    Coding: 0000144
    1 Fault Found:
    Coding: 0000144
    Same answer as other forum - check this :- http://wiki.ross-tech.com/wiki/index.php/01314
  5. Re: A3 1.9tdi cutting out over bumps - HELP!!
    May 2007
    knee deep in clunge
    14 Post(s)
    prone to internal error for voltage supply relay output from ecu
    prone to poor earths engine ecu under nsf headlight
    if the can is dropping out like this it would suggest a faulty node contact in the loom or loose pins at the ecu but consider the voltage and earths, if ok then your left with can problems or can end resistor faulty within the engine ecu
    010 - Open or Short to Plus - Intermittent this is cranking output to starter
    the voltage supply and starter relay share the same multiblock connector inside the engine bay and are not unknown to become corroded
    this is the most current fault with time and date and only gateway gives a clue
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 159
    Mileage: 233477 km
    Time Indication: 0
    Date: 2011.02.28
    Time: 18:53:32
    other control units that are priority on drive train are airbag and abs but only abs sees the coms drop out as gateway is the central hub for all the networks
    so ecu drops out abs loses coms and gateway
    this indicates the network is ok but again the ecu kicks back in without any errors so this points to poor connection either internally or externally
    you need to inspect the ecu connections and wiggle them without damaging the contacts, try running the engine and pull on the loom
    if the ecu voltage drops off then can will lose coms so which one is causing it, normally when the can is corrupted within a control unit it will not work at all, if one of the wires is faulty then single wire will allow the control unit to operate but if the voltage drops then it will stop the control unit until the voltage returns
    good luck
  6. Re: A3 1.9tdi cutting out over bumps - HELP!!
    May 2009
    Belfast
    Trying this on a few forums, so will repost the latest:
    Cleared the DTCs - haven't popped up since yesterday anyways.
    Totally stuck. The car only judders and stalls if I have my foot on the throttle over the bumps, if I coast over them using the clutch in then it continues over them as it normally would.
    Does this narrow it down any?
    Cheers for the help guys - at a total loss here!
    May 2007
    knee deep in clunge
    14 Post(s)
    Sorry you are going to need to get stuck in and try the suggestions mentioned as I can only advise over the web.
    Personally I would tap
    Into the volt supply whilst driving and see if the voltage goes opencircuit when it cuts out as this will localise the fault
    Your looking for dropped voltage or not dropped
    If voltage is still present then check mvb 125 in address 19 for can comms or see if you can still access address 01 when it stalls
    Its very difficult to explain but you need to start somewhere as vag com is a tool not the answer
    Sent from my iPhone using
    My fat fingers
  8. Re: A3 1.9tdi cutting out over bumps - HELP!!
    Oct 2011
    solihull
    Are all the terminals and main supply wires on the battery tight. Had this on an a2. someone had slackened the wrong nut for a battery change.
  9. Re: A3 1.9tdi cutting out over bumps - HELP!!
    May 2009
    Belfast
    Quote Originally Posted by tidla View Post
    Sorry folks - i have committed the cardinal sin of asking for help and not posting when i got it sorted!
    Two main problems, both of which seemed to contribute:
    1) The main earth cable in the engine bay was corroded inside, you could pull it and the engine would stop dead.
    2) This seemed to clear it but then the problem came back fairly quickly - there were fault codes for the engine speed sensor (G28) so replaced that but no joy
    3) The wiring between the engine speed sensor and the ecu was completely replaced - this sorted it! (my mechanic said it was like looking for a needle in a haystack!)
    Thanks for the help everyone!
  1. Please Help A3 1.9TDi (05) Major Flywheel failure
    By goldswj in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-10-2009, 03:34 PM
  2. Audi Cuts New A3 Engine Down To Size
    Last Post: 14-08-2007, 10:18 PM
  3. A3 Range Update
    Last Post: 14-02-2005, 11:35 PM
  4. Audi A3 sportback strikes the best balance
    Last Post: 31-07-2004, 08:36 PM
  5. Unique look for Roomy New Audi A3 Sportback
    Last Post: 23-06-2004, 10:36 PM
