Thread: Brake pedal very high
  1. Brake pedal very high
    Dec 2008
    Sale
    Just taken a 2001 Passat TDI Sport estate for a test drive, all seems very good for it's age and mileage (150K) but the guy said he has recently had some work done to the brakes. They work fine but the pedal sits very (to my mind) high off the floor.
    When I sat in the sar and adjusted the seat to allow me comfotable use of the accelerator and clutch pedal when going for the brakes I initially coaught my foot on the side of the brake pedal and to actually use the brakes was an exagerated lift of my foot onto it. Can this setting be adjusted or does somethung sound wrong??
  2. Re: Brake pedal very high
    The pedal has an upper stop, not adjustable, so this should not happen. What work did he say was done. Regards Peter
  3. Re: Brake pedal very high
    Dec 2008
    Sale
    Didn't really say but it was more than pads/disks, I had a feeling there was a stop. Looks like I'm not buying it now anyway byt thanks.
  4. Re: Brake pedal very high
    london/ UK
    If he had a new servo/master cylinder it could have neen that they have not notted the position of the threaded rod on refitting hence the high pedal...
  5. Re: Brake pedal very high
    Yep that will be the problem if the servo has been changed. The length should be 173.2 mm ± 0.5 mm but always measure when you remove the old one. Regards Peter
  1. High Visibility rear brake light
    By s833son in forum A8 - S8 - V8
    Last Post: 09-07-2014, 03:21 PM
  2. "How To" Front brake pad/disc replacement
    By bora(ing) nick in forum Volkswagen
    Last Post: 24-06-2011, 12:05 PM
  3. Question How can you test a 1994 mk3 Golf td brake servo or vacuum pump
    By tsam19 in forum Golf MK3 - 1993 - 1999
    Last Post: 07-08-2009, 08:03 PM
  4. Side lights show on high level brake light?
    By joeb in forum Golf MK4 - 1999 - 2004
    Last Post: 21-06-2009, 10:15 PM
  5. What Brakes
    By Tonka73 in forum Passat - Archive Topics
    Last Post: 08-01-2007, 01:11 PM
