Thread: A6 C5 Dashboard Problem
Results 1 to 10 of 13
  1. A6 C5 Dashboard Problem
    Sep 2008
    My Audi A6 3.0 v6 Sport has developed the following problem/s today: -
    On starting the car most of the warning lights illuminate in the dashboard and send off an alarm. After a few moments they all disappear and the car drives as normal.
    On switching off the car the warning lights appear again. The dashboard remains illuminated and radio remains switched on and even if I lock the car. I switch off the radio manually and lock the car with the remote locking. After a short while (approx. one minute) the alarm sounds until I unlock the car.
    There is no open windows or anything in the car to cause the alarm to go off.
    This all started today. Can anyone suggest the problem which I suspect may be a faulty relay or fuse?
  2. Re: A6 C5 Dashboard Problem
    Sep 2008
    Quote Originally Posted by volkswagen 1200 View Post
    I have since checked all the fuses which seem fine.
    I now cannot lock the car by the remote or the key because the alarm sounds.
    The instrument cluster continually flashes through various warnings in the driver display screen and the radio would play except I manually switch it off.
    As soon as I switch the car on the warning alarm sounds but immediately goes out once I start the car.
    As soon as I stop the engine the alarm sounds again.
    The only thing that I can do to stop the warning in the cluster display and return the dashboard to normal is turn the instrument cluster left setting knob fully to the right and hold it there. Once I let go the instrument cluster illuminates with warnings again and the radio resumes playing.
    I also ran a VCDS-lite diagnostics as follows: -
    Chassis Type: 4B - Audi A6 C5
    Scan: 01,02,03,06,08,15,16,17,18,34,35,36,37,45,55,56,57 ,65,67,75,76,77
    Address 01: Engine Labels: 06C-909-559-ASN.LBL
    Controller: 8E0 909 559 H
    Component: 3.0L V6/5V G 0001
    Coding: 0011752
    Shop #: WSC 02325
    No fault code found.
    Readiness: 0000 0000
    Address 02: Auto Trans Labels: 01V-927-156.LBL
    Controller: 4B0 927 156 EN
    Component: AG5 01V 3.0l5V RdW 0808
    Coding: 0000001
    Shop #: WSC 00000
    Address 03: ABS Brakes Labels: 4B0-614-517.LBL
    Controller: 4B0 614 517 H
    Component: ABS/ESP allrad 1728
    Coding: 06397
    Shop #: WSC 00000
    1 Fault Found:
    01119 - Gear Recognition Signal
    35-10 - - - Intermittent
    Software Coding: 07915
    3 Faults Found:
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01561 - Shareware Version. To Decode all DTCs
    59-10 - Please Register/Activate - Intermittent
    01134 - Shareware Version. To Decode all DTCs
    49-10 - Please Register/Activate - Intermittent
    Software Coding: 00462
    6 Faults Found:
    00667 - Ambient Temperature Signal
    30-10 - Open or Short to Plus - Intermittent
    01176 - Shareware Version. To Decode all DTCs
    07-10 - Please Register/Activate - Intermittent
    00849 - Shareware Version. To Decode all DTCs
    31-10 - Please Register/Activate - Intermittent
    01314 - Engine Control Module
    49-10 - No Communications - Intermittent
    01315 - Shareware Version. To Decode all DTCs
    00562 - Shareware Version. To Decode all DTCs
    29-10 - Please Register/Activate - Intermittent
    Can anyone tell me what the problem is?
  3. Re: A6 C5 Dashboard Problem
    Sounds like the instument cluster is on the way out.
    Mine did this, lighting up all the time, funny noises, then alarm kept going off, eventually the immobilizer (which is in the dash pod) went and the car wouldn't start.
    You will likely either need a new dash (£600 and has to be fitted by main dealer or independant with the dealer kit). Or you can send the dash to BBA Reman and others who can repair the dash pod, think it takes about 2-3 weeks to get it back though so no car whilst this happens.
    I am a bit ocnfisued byt he VCDS scan, where are the other controllers? What happens when you scan address 17 Instruments?
  4. Re: A6 C5 Dashboard Problem
    Apr 2009
    I would first check that the terminals along the bottom of
    the relay board are all tight. Also the plugs that go into
    the back of the instrument cluster.
    Regards
    Jim
  5. Re: A6 C5 Dashboard Problem
    Southern County Softy
    20 Post(s)
    check the front pax footwell for damp.
    The CCM lives under the seat and is known to fail due to water ingress, have a search for "blocked plenumn drains"...
    A4 2.5 tdi QS (mapped)
  6. Re: A6 C5 Dashboard Problem
    Sep 2008
    Quote Originally Posted by iwaters View Post
    The missing ones came up with the message "unable to communicate".
  7. Re: A6 C5 Dashboard Problem
    Sep 2008
    I ran another analysis tonight as follows: -
    Self-Diagnosis Log
    Monday, 28 March 2011, 21:36:53:0
    Mileage: 65875 Repair Order:
    Coding: 0011752
    Shop #: WSC 02325
    Coding: 0000001
    Shop #: WSC 00000
    Coding: 06397
    Shop #: WSC 00000
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    01119 - Shareware Version. To Decode all DTCs
    35-10 - Please Register/Activate - Intermittent
    3- ABS Brakes
    Control Module Part Number: 4B0 614 517 H
    Component and/or Version: ABS/ESP allrad 1728
    Software Coding: 06397
    2 Faults Found:
    17 - Instruments
    Control Module Part Number: 4B0 920 981 K
    Component and/or Version: KOMBI+WEGFAHRS. VDO D10
    6 Faults Found:
    00667 - Shareware Version. To Decode all DTCs
    I could not obtain readouts from most of the other controlers that I tried, instead just getting a "could not communicate" message.
    The battery of the car is now being drained also.
  8. Re: A6 C5 Dashboard Problem
    Sep 2008
    I removed the instrument cluster tonight in order to take the part number off it. At the same time the battery had totally gone flat because of the fault.
    Having replaced the instrument cluster and recharged the battery I now find that everything is working as normal again.
    Am I wrong to think that everything could have been fixed from a basic 're-start' or is this problem going to return?
  9. Re: A6 C5 Dashboard Problem
    Sep 2008
    Quote Originally Posted by kite View Post
    I have lifted the mats and there is absolutely no damp anywhere to be found.
  10. Re: A6 C5 Dashboard Problem
    Sep 2008
    I checked the passenger foot well and it is completely dry.
  1. Audi a6 C5 Remote central locking problem
    By mmm777 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-06-2025, 01:07 PM
  2. Advanced new audi a6 travels light to tackle emissions
    Last Post: 11-12-2010, 07:22 PM
  3. A6 Multitronic problem, gear selector flashing sometimes
    By Rockafella808 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 09-08-2010, 04:57 PM
  4. help~ 99 A6 1.8T engine start problem
    By bjtupp in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-03-2008, 09:23 PM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
