Thread: passat tdi awx
  1. passat tdi awx
    Jul 2007
    chepstow
    i have a passat tdi awx and if i drive it gently it is fine thought the revs but if you accelerate hard it then lacks power and has bad hesitation almost like a misfire due to lack of fuel i have replaced fuel filter and if you pull the hose off the fuel tank pump and turn the ignition on fuel is pumped out but the jet of fuel only reaches about 1.5 inches hight and doesn't seem to have any pressure to it is this normal
  2. Re: passat tdi awx
    Chester-le-Street, United Kingdom
    you need to get codes read, it could be anything, and you have already paid out for a fuel filter.
    be kind on yourself, get it read and save some cash,
    regards,
    stewy.
    first time i was up a ladder i was down a well
    4th cog,--two to go
  3. Re: passat tdi awx
    Jul 2007
    chepstow
    sorry forgot to mention checked codes and nose stored
  4. Re: passat tdi awx
    Jan 2006
    Near Basingstoke
    never pulled the fuel line off mine to see how much pressure you should get (some clever people on here will probably be able to tell you) but as the fuel is flooded through the head channels and dispensed under great pressure from the individual (PD) unit injectors I wouldn't expect too much pressure from the filter outlet?
  5. Re: passat tdi awx
    Norfolk
    Hesitation/misfire and no codes. Change the injector loom. Tank pump is a lift pump to get fuel to the filter. No pressure needed really.
  1. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-11-2007, 07:33 PM
  2. Hello from new member after advice....
    By margie in forum New Member Introductions
    Last Post: 28-06-2007, 11:20 PM
  3. Passat TDI 170 Cruise Control Fault
    By passat170 in forum Archive posts
    Last Post: 27-06-2007, 12:28 PM
  4. The Passat Bluemotion – Uk Market Information
    Last Post: 02-05-2007, 07:28 PM
  5. Golf GT TDI or Upgrade the Passat V6TDI
    By LWW in forum Chat - Completely Off Topic
    Last Post: 30-10-2006, 08:50 PM
