Thread: Torque setting for Tdi Alternator pulley?
Results 1 to 10 of 16
  1. Torque setting for Tdi Alternator pulley?
    Chipped2 Guest
    Does anyone have Torque setting for tightening new freewheeling alternator Pulley? Pig to get off! Help please as it's not in Haynes as expected!
  2. Re: Torque setting for Tdi Alternator pulley?
    Chipped2 Guest
    Think I've just found it online ant 80nm
  3. Re: Torque setting for Tdi Alternator pulley?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    The recommended torque ( by INA bearing Co. maufacturer of clutch bearing) is 85Nm (63 ft.lb.) This was the torque supplied by INA for both a VW Polo 1.4 TDI Alternator bearing and for the MK5 Golf 1.9TDI Alternator ( Valeo 140A). The P/No. fpr the bearing is the same for both. Not sure about Passats. I too couldn't find this info on the internet and Emailed INA direct and got a swift reply . - Good Company ! I posted this info previously on the Golf MK5 forum.
    Incidently the cost of this bearing from GSF was half that from VW dealer . The INA bearing P/No. was the same from both sources.
    Skoda Octavia II SE 1.9PD TDI
  4. Re: Torque setting for Tdi Alternator pulley?
    Quote Originally Posted by Chipped2 View Post
    Why was it a pig to get off, did you not have the correct tool?
  5. Re: Torque setting for Tdi Alternator pulley?
    Chipped2 Guest
    vwcabriolet1971.
    Thanks for the Torque setting . Your 85nm is obviously correct as you had it straight from the horses mouth so to speak. Did see it on a posting recently but could neither remember it or where it was so ended up on a US site through Google. 80nm will have to do this time.
    Caldirun.
    Have the Laser splined tool but pulley was very tight. Finally shocked it free with a heavy mallet. Didn't have a proper tool to hold the viscous fan but managed with a chain wrench and a strip of DPC. The old pulley tests OK but clearly isn't as the tensioner is now more stable and the 'chirping' has gone. Will replace tensioner at 180k if it lasts till then.
  6. Re: Torque setting for Tdi Alternator pulley?
    vwcabriolet1971.
    Caldirun.
    I have removed my fan twice, once to replace the tensioner and again to replace the alternator pulley, I found no special tool was required just a hex key from the rear to remove the centre bolt!
  7. Re: Torque setting for Tdi Alternator pulley?
    Jul 2007
    Chester
    Quote Originally Posted by caldirun View Post
    How did you hold the fan ?
    Audi TT 1.8T Quattro 225 - Sold , AUDI A4 1.9 TDI 130 AWX - now
  8. Re: Torque setting for Tdi Alternator pulley?
    Chipped2 Guest
    Quote Originally Posted by sabikeuk View Post
    I used a cheap chain wrench with a strip of plastic damp proof membrane to protect pully surface....... not ideal as handle of chain pulley broke off and remaining was pushed into flattened steel tube!!
    Have since bought a Sealey AK604 oil filter strap wrench for use in future as mine was so tight. Bought from CCW tools, half price at £13.33 , very well made item.
  9. Re: Torque setting for Tdi Alternator pulley?
    Jul 2007
    Chester
    Thanks for reply. I have got oil filter strap wrench so basically I just need to hold viskose clutch with wrench ?
  10. Re: Torque setting for Tdi Alternator pulley?
    Chipped2 Guest
    You will be turning aux belt tensioner pulley nut anti clockwise which will release tension on the Aux. belt so that it can be taken off the Alt pulley. I keep my belt tied up to keep tension on the pulleys so that they remain in their correct grooves below.
    Oil filter strap is then used on the smooth viscous fan pulley to hold it, enabling retaining bolt to be undone and subsequently tightened if like mine it was 'tight'.
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. 170 turbo from a golf into a passat
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-11-2010, 11:19 AM
  3. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  4. New bentley continental supersports convertible
  5. MK5 GT Road wheel bolt Torque setting
    By steve baker in forum Golf MK5 - 2004 - 2009
    Last Post: 03-09-2007, 12:47 PM
