Thread: LT35 coolant system
  1. LT35 coolant system
    Dec 2006
    I have a long running problem with the coolant system on a 99 LT 35 2.5L engine. Could anyone explain the role and purpose of the small vacumn value in the lower radiator line?
    Many Thanks
  2. Re: LT35 coolant system
    Apr 2009
    essex uk
    The valve ensures the coolant is circulated adequately onto the pump further down the line, and onto the heat exchanger, for heating.
    If it was'nt there, or not working properly, you would have probs with lack of heat on blowers, and overheating on the engine, as the complete circuit needs to be operated to a certain pressure
  3. Re: LT35 coolant system
    Dec 2006
    Thanks rob, worthy of further investigation then. The vehicle over heats on any form of hill in high gear, I need to be reving the **** of it in lower gears to help it stay within acceptable (anything less than steam escaping) levels.
    One thing i have noticed when it overheats is an apparent 'air lock' in the short length of pipe between the lower radiator inlet and the 'T' junction in the pipe work leading up to it. The other side of this 'T' joint going to the thermostat in the engine and the 3rd arm of the T going to this vacuum valve.
    When it overheats all the other pipes are hot except this short length! Any further thoughts on this or on testing the operation of the valve would be most welcome
  1. The new bentley continental gt
    Last Post: 26-09-2010, 03:44 PM
  2. All-new audi a8 travels light to miami debut
    Last Post: 02-12-2009, 08:58 PM
  3. Replies: 0
    Last Post: 14-11-2007, 10:16 PM
  4. vag codes
    By new to vw in forum Passat - Archive Topics
    Last Post: 29-12-2006, 12:19 AM
  5. The new Audi A6 Avant
    Last Post: 20-11-2004, 09:09 PM
