Thread: Westfalia towbars interchangeable?
  1. Westfalia towbars interchangeable?
    Mar 2011
    Toronto, Canada eh.
    Hi, 1st post.
    Installed a Westy "automatic detachable towbar" in my '09 Mark V GTI, very happy with it except the ball height is a little high for my trailer. The easy fix would be to fit another towball with a lower ball height.
    Here's mine:
    As you can see the trailer sits nose high, I need the ball 2-3" lower to level it:
    Will this hitch for a Range Rover work?
    And before anyone says ewwww, talk to my FAST, but careful, he bites!
  2. Re: Westfalia towbars interchangeable?
    Mar 2011
    Toronto, Canada eh.
    100+ views and no one knows?
  3. Re: Westfalia towbars interchangeable?
    Mine (on an A6 Avant) is also higher than I'd like it to be, and too close to the bumper as well. And I'm not impressed that there is no attachment on the towing bracket for a breakaway cable. As far as I know, they don't make interchangeable tow balls of different heights. They could do with being better designed in the first place.....
  4. Re: Westfalia towbars interchangeable?
    Mar 2011
    Toronto, Canada eh.
    Thanks for the reply. I can confirm that this towball is NOT interchangeable.
    Bought one off Flee-Bay, had a buddy send it accross the pond and it doesn't fit.
    I think what I'll do is make a new receiver tube and weld it in place, it would be the perfect height for my trailer.
  5. Re: Westfalia towbars interchangeable?
    Nov 2008
    Lincoln, UK
    Quote Originally Posted by drkailey View Post
    Just seen this thread. Whatever you do, DO NOT alter the tow bar as fitted to the car. It is type approved and if you alter it and it breaks, causing an accident, you will be liable.
    Why not modify the trailer tow hitch mounting so the trailer chassis sits level? Likely you will just need a form of spacer and longer bolts.
    63 Audi A3 1.4 TFSI Sport
    Gone: 10MY Freelander 2 TD4 HSE Auto, Stornaway Grey. 55 SEAT Alhambra SX 130TDi (Grandad's taxi/shed) Freelander 2 TD4 SE manual, Rimini Red. 07 Passat Est SE 2.0 TDI 140 DSG Blue Graphite
  6. Re: Westfalia towbars interchangeable?
    Coventry
    As said, DO NOT alter the towbar on the car. It is correctly fitted and designed and the ball is the correct height off the road.
    Add a space plate between the trailer hitch and the chassis.
  7. Re: Westfalia towbars interchangeable?
    Feb 2010
    Devon
    Without trying to be unkind but if you put proper trailer tyres on your modded trailer rims the trailer would already be at the correct height/level!
    06 (my2006) Passat Estate 2.0 TDI SE 140bhp (BKP110710), MFD2, Premium Phone, 6CD Multichanger, MFSW, 4 new injectors!!!
  1. Tow Bars and fitting
    By Discretion in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 08-09-2010, 12:54 PM
  2. Seat Leon New Westfalia towbar in stock
    By PFJones in forum Leon
    Last Post: 13-11-2009, 01:24 PM
  3. Is the S3 and 4Motion rear diff interchangeable?
    By Mokeylock in forum Archive posts
    Last Post: 28-02-2007, 01:46 PM
