Thread: parking sensor
  1. parking sensor
    Mar 2011
    leicester
    hi
    new to all of this but having trouble with parking sensors .i have had i code read and was told o/s/f sensor o/c or short to ground is it just a case of striping out front loom and checking for breaks as i am pulling my hair out with thisreally could do with help
  2. Re: parking sensor
    Apr 2007
    France
    12 Post(s)
    Problems are usually caused by water getting in them. Apparently they're pretty rubbishy anyway (I've not got them on mine!).
    1996 Laguna 2.2D
    1977 MGB roadster
  3. Re: parking sensor
    Nov 2008
    Basingstoke
    As Quatrelle said, probably water in the sensor. I was quoted about £200 to replace one, ended up drying it out with a hairdrier for (next to) nothing.
  4. Re: parking sensor
    Mar 2011
    leicester
    stripped out complete front loom today and found corroded wire repaired all working again thanks
  5. Re: parking sensor
    Jan 2010
    SE UK
    Getting a fair few spurious bleeps from my front ones too - normally as i am reversing , grrr !
    Had no wet weather for days and days, so guessing wiring needs a check - seems like a poor fit if this is common.
    Did you find the wiring had bared, or connectors worked loose / corroded ?!
  6. Thumbs up Re: parking sensor
    Mar 2011
    leicester
    have you had it on a code reader it will tell you the fault
    mine was wire corroded right in the middle of the loom behind the front grill well worth getting code read easy enough to remove front loom and repair
    if you put your finger over each sensor you should feel it pulsing if you find one not pulsing swap with one of the others to check not faulty
  1. Please Help Location of Parking Sensor Control Box in Audi A4 Avant 2005
    By Adam Ravat in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-01-2010, 09:21 PM
  2. Rear parking sensor part number.
    By kelvinrp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-01-2010, 03:02 PM
  3. ABS Sensor: ABSolute pain!
    By tornadored7 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-11-2009, 04:04 PM
  4. "How To" The FAQ & How To Thread
    By Ben in forum General
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
