Thread: Very poor mpg
Results 1 to 10 of 15
  1. Very poor mpg
    6 Post(s)
    Golf tdi 130 pd Tdi ASZ engine.
    I have really bad mpg on boost. I can get 40-50mpg downhill or coasting along but as I go above 2000rpm the mpg goes to late 20's and averages about 30mpg.
    I have fully serviced the car including fuel filter, air filter, temperature sensor and I replaced the vacum hoses with new silicone ones.
    It's quite loud on boost but performance is ok and no black smoke
    I can't see anything obvious from the specified and actual on the Map or boost side?
    I have disconnected the MAF and get the same mpg as if is plugged in but obviously the car is slow, using virtually no boost when MAF disconnected.
    Getting no VAGCOMM errors.
    Can anyone spot anything in the reading: Thanks!
  2. Re: Very poor mpg
    6 Post(s)
    I suppose what I am asking is shall I replace the MAF?
    Could the readings be faulty?
    Thanks!
  3. Re: Very poor mpg
    Southampton, UK.
    Symptoms sound like it could be a dodgy AMM (aka MAF). I asked Crasher a while back about how an amateur like me could diagnose a failing AMM using VAG-COM. Essentially, he said don't bother - he'd given up trying. When you change the AMM, get a genuine exchange one from VW.
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 379,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
    2015 Audi A6 2.0 TDI ultra 190
  4. Re: Very poor mpg
    6 Post(s)
    Thanks Herby
    I thought the readings on VAG-COM that log the actual versus specified were a way of checking the MAF or can they simply give up and give nonsense!?
  5. Re: Very poor mpg
    Southampton, UK.
    I don't know enough about the readings that are pumped out to say, but it sounds logical what you're saying. Need someone more experienced to comment on this. If the AMM is giving duff values to the ECU, the the car will run poorly. If the actual and specified values are meant to be +/- 5% say, the I suppose you can diagnose a faulty one. From what I've been told, it's a bit more of a black art. Often I hear that the AMM just deteriorates slowly, so the decline in overall performance and mpg just creeps up and it doesn't log any codes.
  6. Re: Very poor mpg
    6 Post(s)
    I drove my car home yesterday and gave it some beans and the MPG was no worse really?
    Does anyone have any other suggestions???. I'm desperate to sort it
  7. Re: Very poor mpg
    134 Post(s)
    2005 Post(s)
    You are looking at the instantaneous mpg, it bounces around all over the place, only go by your average mpg.
  8. Re: Very poor mpg
    6 Post(s)
    Hi Crasher,
    No. I am not using the instant mpg it's jibberish. I only use the average.
    The instant one varies from 11-60mpg!?
    What can I try next? Is there anything else I can log and check!?
  9. Re: Very poor mpg
    6 Post(s)
    Just to clarify a motorway journey I am lucky to get mid 30's on average.
    Off gas I get 40's but I know this is not reliable as I am not really using the accelerator.
  10. Re: Very poor mpg
    6 Post(s)
    Quote Originally Posted by robert1z View Post
    Thanks Herby
    Can anyone give me an idea if I wasting my money buying a MAF to hope the mpg improves or is it worth a shot?
