Thread: Multiple faults with Comfort Databus
  1. Question Multiple faults with Comfort Databus
    Aug 2008
    Aldershot
    Hi all
    I am new owner of A8L (D3 2006) and have just scanned it for faults. it came back with multiple faults for combination comfort databus. I am aware of a fault with driver power electric door closure, but did not expect this amount of faults. Everything else work ok. I understand that maybe just one of the modules might be throwing all of them as they all sit on a bus. Any ideas where to start?
    Logs below.
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
    Component: KLIMAAUTOMAT 017 0450
    Revision: 00000032 Serial number: 00000000093086
    Coding: 0084081
    Shop #: WSC 02311 785 00200
    VCID: 1C3C5186A6C3
    4 Faults Found:
    00470 - Combination comfort Databus in Single Wire
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 3
    Fault Frequency: 4
    Reset counter: 251
    Mileage: 260417 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 11:24:59
    Freeze Frame:
    ON
    00066 - Right Rear Footwell Heater (Z43)
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 250
    Mileage: 260417 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 11:25:03
    Freeze Frame:
    Voltage: 13.50 V
    00065 - Left Rear Footwell Heater (Z42)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 260417 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 11:25:49
    Freeze Frame:
    Voltage: 13.50 V
    00565 - Rear A/C Control Head (Climatronic) (E265)
    013 - Check DTC Memory
    Freeze Frame:
    Fault Status: 00000100
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 24
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 Q HW: 4E2 955 113 B
    Component: ILM Fahrer H14 0230
    Coding: 0143121
    Shop #: WSC 02313 785 00200
    VCID: 3668A32E382F
    Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000037
    Shop #: WSC 02313
    Part No: 4E0 910 557 A
    Component: REGENLICHTSENSORH12 0090
    Coding: 00139548
    Shop #: WSC 02313
    1 Fault Found:
    01336 - Data Bus for Comfort System
    Freeze Frame:
    Fault Status: 01101101
    Fault Priority: 2
    Fault Frequency: 247
    Reset counter: 251
    Mileage: 243834 km
    Time Indication: 0
    Date: 2010.10.20
    Time: 17:32:10
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
    Component: Gateway H11 0090
    Revision: 11 Serial number: 20003063118031
    Coding: FCFF7FDE2B7504
    VCID: 27567E6AEF85
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 252
    Mileage: 260417 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 11:25:52
    Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
    Part No SW: 4E0 910 218 A HW: 4E2 905 218 B
    Component: FPI_1 H01 0010
    Revision: 01000101 Serial number: 05122005103246
    Shop #: WSC 00000 000 00000
    VCID: 1F46668AB7D5
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 251
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 13:42:28
    Address 28: HVAC, Rear Labels: None
    Part No SW: 4E0 910 158 HW: 4E0 919 158 D
    Component: KLIMA-STG. FOND 017 0230
    Revision: 00000019 Serial number: 00000000051426
    Coding: 0000000
    VCID: E1C2A0724121
    4 Faults Found:
    01087 - Basic Setting Not Performed
    005 - No or Incorrect Basic Setting / Adaptation
    01863 - Air Outlet Motor; Left Rear (V218)
    003 - Mechanical Failure
    01864 - Air Outlet Motor; Right Rear (V219)
    Address 42: Door Elect, Driver Labels: None
    Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
    Component: T¸rsteuer.FS BRM003 0100
    Coding: 0032750
    Shop #: WSC 00000 785 00200
    VCID: 204465768AAB
    1 Fault Found:
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 252
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 16:56:58
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 B HW: 4E0 907 289
    Component: Komfortgeraet H05 0010
    Revision: 00100005 Serial number: W040603090368
    Coding: 0004829
    VCID: 28547D56E29B
    Part No: 4E0 907 719
    Component: Neigungssensor H05 0020
    1 Fault Found:
    00985 - Right Tail Light (M2)
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 36
    Mileage: 260420 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 13:49:02
    Address 52: Door Elect, Pass. Labels: None
    Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
    Component: T¸rsteuer.BF BRM003 0100
    Coding: 0032750
    VCID: 204465768AAB
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 252
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 16:56:58
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
    Component: T¸rsteuer.HL BRM003 0100
    Coding: 0032750
    VCID: 1E385B8EB0DF
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 252
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 16:56:58
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
    Component: T¸rsteuer.HR BRM003 0100
    Coding: 0032750
    VCID: 1E385B8EB0DF
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 252
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 16:56:58
  2. Re: Multiple faults with Comfort Databus
    May 2007
    knee deep in clunge
    14 Post(s)
    go into address 17 or 19 and check the bus network status, normally mvb 125 you may find the info in the vcds label files
    1 = comms ok 0= not ok then scope the dash can wires for to check for open circuit short to +/-
    the info points to a defect on the wiring to the dash or the dash itself
  3. Re: Multiple faults with Comfort Databus
    Aug 2008
    Aldershot
    Thanks for very quick answer. Excuse me, but I ma not sure i follow you 100%. I have gone into 17 - no faults. 19 show this:
    Address 19: CAN Gateway Labels: 4E0-910-468.LBL
    Control Module Part Number: 4E0 910 468 B HW: 4E0 907 468 E
    Component and/or Version: Gateway H11 0090
    Software Coding: FCFF7FDE2B7504
    Work Shop Code: WSC 02313 785 00200
    VCID: 27567E6AEF85
    1 Fault Found:
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 14
    Reset counter: 253
    Mileage: 260417 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 11:25:52
    What do you mean by scope the dash wires? Physical test with multimeter?
  4. Re: Multiple faults with Comfort Databus
    May 2007
    knee deep in clunge
    14 Post(s)
    if you access the measured value function in this address then enter block 125 this will show all the bus drives and hopefully show you if the bus coms are down from the dash
    to scope would mean to tap into the dash canbus wires and use a oscilloscope to check both high and low signals are present
    if only one is present then check the wire for open circuit
    because rosstech removed the label files from wiki i cant check the measured values for you
    each bus circuit has two wires
    can high and can low
    they are a mirror image signal so if one fails it goes into single wire mode to keep the network functioning, there are can nodes which you can tap into to check both signals are present
    you can check with a multi meter but you must disconnect the individual circuit for a resistance check if you do not then you will pick resistance up as each consumer has a end stage so you must disconnect to check in the more conventional ohms check
  5. Re: Multiple faults with Comfort Databus
    Aug 2008
    Aldershot
    In 19 adv meas value are grayed out. Block 125 shows as below.
    Address 19: CAN Gateway (4E0 910 468 B)
    19:34:22 Group 125
    Engine 1
    Transm. 1
    ABS Slp.Ind
    Instruments 1
    Saturday,19,March,2011,19:45:52:60804
    I think i understand the idea of a bus. interesting to find out they are doubled up. I think I it is above my ability to fault find this. you are talking about wiring, wouldn't a module failure cause the same issue? it used to happen in my old days of alarm fault finding (house alarms).
    Anyone more experienced in the south to try to tackle this?
  6. Re: Multiple faults with Comfort Databus
    May 2007
    knee deep in clunge
    14 Post(s)
    yes the dash module could be the cause but as long as one can wire is present then the dash will function
    clear the faults and try again in a few days, if there is still a single wire fault then it would be advisable to have it checked out but the funny thing is the faults only started today with low frequency of occurrence
    the drivers door has a dash wake up wire, this turns the dash on when you open the door
    this may well be related to your power closure issue and can problem
    Coding: 0032750
    VCID: 204465768AAB
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 0
    Reset counter: 252
    Mileage: 260416 km
    Time Indication: 0
    Date: 2011.03.19
    Time: 16:56:58
  7. Re: Multiple faults with Comfort Databus
    Aug 2008
    Aldershot
    ok thanks,
    fault shows as it have started today following me clearing all the faults. (it was there before as well). I will take the door apart probably next weekend, and check whats going on. I will probably then disconnect the module in the door to check if it would clear the fault.
    Thanks for your help.
  1. Lots Of Faults
    By marf in forum A8 - S8 - V8
    Last Post: 23-03-2011, 10:50 PM
  2. Engine Faults
    By blacksline in forum VCDS - General Questions
    Last Post: 28-10-2010, 11:33 PM
  3. Please Help retrofit comfort and memory seat
    By aristidis in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2010, 05:23 AM
  4. multiple faults on dash
    By lonky in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-03-2010, 11:05 PM
  5. Please Help my head will explode soon!
    By carmanic in forum Golf MK5 - 2004 - 2009
    Last Post: 07-02-2010, 08:05 PM
