Thread: Whine from audio tweeters - Accepted by factory as known fault
  1. Exclamation Whine from audio tweeters - Accepted by factory as known fault
    Aug 2010
    Uk
    Hi All,
    Just to let you know an issue I have been chasing with VW regarding a high pitched whine that comes from the hifi system that you can hear when music is low/off has been acknowledged by VW Germany as a fault.
    The Whine pitch rises and falls with engine revs, so may be linked to alternator.
    I am unsure if it is only certain vehicle spec (dynaudio/xenon) but I certainly have it on mine. Thankfully you can't hear anything if you turn the music up or are OLD!! lol
    If you you are hard of hearing get someone to put their ear by a door tweeter and rev the engine a bit to see if you have the issue.
    They are working on a fix!!
  2. Re: Whine from audio tweeters - Accepted by factory as known fault
    Aug 2010
    Uk
    Also, while I am here.
    due to the above VW swapped my Alternator out last week to see if that was the cause (it wasn't) and I swear that ever since whenever the car does stop/start the stereo mutes/cuts on engine restart! ... pretty sure this didn't happen before. Can someone confirm please?
  3. Re: Whine from audio tweeters - Accepted by factory as known fault
    Jan 2010
    uk
    Quote Originally Posted by rmccardal View Post
    I have Dynaudio, with RNS510, but Halogen lights.
    No whistle here.
    Must be bloody annoying after paying for the hi-fi upgrade
  4. Re: Whine from audio tweeters - Accepted by factory as known fault
    Aug 2010
    Cheshire
    I had similar issues with a vectra I had. It would buzz/whine through the speakers when certain things were connected to the 12 volt power socket. I presume you dont have anything plugged in?
    Spec Ordered: 170GT, pearlescent black, keyless, heated sceen, aircon seats, MDI
    Order confirmed on 16 September 2010
    estimated supply date: November 2010
    Actuall build date: 23 March 2011
    Collected: 4 April 2011
    Aug 2010
    Uk
    Nope, nothing in the 12v. It's just picking up interference from electrical systems that's it's supposed to be isolated from.
    Could be a ground loop/ bad earth somewhere, but as the factory say it's know I think it might be to do with the bluemotion changes personally.
    Anyone got any info on the radio muting on stop/start??
  6. Re: Whine from audio tweeters - Accepted by factory as known fault
    Aug 2010
    Egremont, UK
    Mind does not, however, I have the standard speakers.
  1. Avant tailgate and MMI issues - connected?
    By ukandyb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-12-2014, 01:39 AM
  2. Help please - electrical woes after towbar fitting
    By dstanley in forum VCDS - Help Requests
    Last Post: 22-02-2011, 01:03 AM
  3. Please Help Help With MIL !!!
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-11-2010, 07:46 PM
  4. Question what does this mean
    By mango in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-10-2010, 11:18 AM
  5. Help needed from experinced A6 owners
    By robmorphet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-03-2010, 08:27 AM
