Thread: vcds help
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. vcds help
    Mar 2011
    stockholm
    Hey, im new with this vcds system. bought it because my wipers and my horn stop working. my wipers start working full speed sometimes for 10 minutes. i cant stop them, even if i turn of the ignition and pull the fuse.
    can anybody help me reading my diagnose? the car is a caddy 07
    thanks
    Friday,18,March,2011,16:38:22: 60804
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 1K0
    Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
    VIN: WV1ZZZ2KZ7X050697 Mileage: 153410km/95324miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    42-Door Elect, Driver -- Status: Malfunction 0010
    56-Radio -- Status: Malfunction 0010
    Address 01: Engine ( ) Labels: None
    Part No SW: 06G 997 022 A HW: 06G 906 022 A
    Component: 4220 CNG 26B6 5304
    Revision: --H01--- Serial number: VWZ7Z0F7143365
    Coding: 0030071
    Shop #: WSC 40963 222 85004
    VCID: 2B5E825AF36D
    1 Fault Found:
    000406 - Engine Oil Temp. Sensor (G8): Implausible Signal
    P0196 - 004 - No Signal/Communication - Intermittent
    Readiness: 0000 0001
    Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
    Part No: 1K0 907 379 P
    Component: ASR FRONT MK70 0105
    Coding: 0017106
    Shop #: WSC 35110 377 00189
    VCID: 3F86C60A1715
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Address 08: Auto HVAC Labels: 1K0-820-047.lbl
    Part No: 1K0 820 047 FJ
    Component: Climatic PQ35 120 0606
    Shop #: WSC 00000 000 00000
    VCID: 71E2503211C1
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
    Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
    Component: Bordnetz-SG H37 1002
    Revision: 00H37000 Serial number: 00000006210122
    Coding: 088CCF030004100000000000000000 000008FB075C
    Shop #: WSC 35110 377 08192
    VCID: 2A50875EFC97
    Component: Fehler Lin-Slave 01
    4 Faults Found:
    01493 - Bulb for Blinkers; Front Left (M5)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    00906 - Horn (H1)
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.85 V
    OFF
    ON
    OFF
    OFF
    OFF
    02071 - Local Databus
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.80 V
    OFF
    ON
    OFF
    OFF
    OFF
    00153 - Windshield Wiper Motor; Driver Side (V216)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 12
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.80 V
    OFF
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
    Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
    Component: 09 AIRBAG VW52 023 2400
    Revision: 04023000 Serial number: 0037TD0BK2TS
    Coding: 0012345
    VCID: 7DFA7C025D99
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
    Component: Lenks‰ulenmodul 636 0070
    Coding: 0000012
    VCID: 74EC59266ED3
    1 Fault Found:
    00883 - Ignition Switch (D) Terminal S
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1T0 920 862 B
    Component: KOMBIINSTRUMENT VDD 0622
    Coding: 0017101
    Shop #: WSC 80093 222 69422
    VCID: 32609F3ED447
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    008 - Implausible Signal - Intermittent
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 H HW: 1K0 907 951
    Component: J533__Gateway H04 0010
    Revision: H04 02 Serial number: 15070602000042
    Coding: 3D0F034007007400
    VCID: 2C5C8146F663
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
    Component: IMMO VDD 0622
    Shop #: WSC 40972 222 55038
    VCID: 32609F3ED447
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
    Part No SW: 1T0 959 701 E HW: 1T0 959 701 E
    Component: Tuer-SG 005 0943
    Coding: 0000048
    VCID: 3972A8120931
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    005 - No or Incorrect Basic Setting / Adaptation
    Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
    Part No: 1K1 909 144 L
    Component: EPS_ZFLS Kl.140 H07 1806
    Shop #: WSC 35110 666 38454
    VCID: 346C99262E53
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 AK
    Component: KSG 0401
    Coding: 00890C087F2D8405484A016010C0
    VCID: 79F2681249B1
    Component: Sounder n.mounted
    Component: NGS n.mounted
    Component: IRUE n.mounted
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
    Component: Tuer-SG 005 0929
    Coding: 0000048
    VCID: 3972A8120931
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD
    Component: Radio BVX 034 0046
    Revision: 00034000 Serial number: VWZ1Z2G4805413
    Coding: 0010400
    VCID: 68D43D56221B
    3 Faults Found:
    01042 - Control Module; Not Coded
    000 - -
    00872 - Bass Speaker Rear Left (R15)
    011 - Open Circuit
    00873 - Bass Speaker Rear Right (R17)
    011 - Open Circuit
  2. Re: vcds help
    Ireland
    You appear to have faults in 7 modules, which is a alot. Why dont you clear all the faults and see what comes back.
    Your horn and wipers are controlled via the same module (09-Cent. Elect), its quite possible you issue is common to both faults.. Find the module and have a good look at it..
    14 1.2T Beetle 105bhp
    15 535d 313bhp
    VCDS HEX V2
  3. Re: vcds help
    134 Post(s)
    2016 Post(s)
    As has been said, clear all the codes and see what comes back. Check the horn wiring to the horn itself; it often rubs through on the bumper support bracket screw.
  4. Re: vcds help
    Mar 2011
    stockholm
    ok, thanks for the help, i appreciate it.
    I already cleared all the codes and this one is the last one.
  5. Re: vcds help
    Norfolk
    What is??
  6. Re: vcds help
    Mar 2011
    stockholm
    Quote Originally Posted by martin1810 View Post
    What is??
    The vcds result.
  7. Re: vcds help
    Ireland
    You should go into (09-Cent. Elect) and complete an output test. this should test your horn and the different stages of your wiper motor.
    This will allow you to narrow down the issue.
    Does the car have a good battery? Are you having starting issues?
    15 535d 313bhp
    VCDS HEX V2
  8. Re: vcds help
    Mar 2011
    stockholm
    Quote Originally Posted by burkey1 View Post
    yes, i had some starting problem below -20c temp. and the battery discharges easy.
    this is the 09-Cent. Elect test:
    Saturday,19,March,2011,10:28:35:60804
    Control Module Part Number: 3C0 937 049 D HW: 3C0 937 049 D
    Component and/or Version: Bordnetz-SG H37 1002
    Software Coding: 088CCF030004100000000000000000000008FB075C
    Work Shop Code: WSC 35110 377 08192
    Additional Info: Fehler Lin-Slave 01
    VCID: 2A50875EFC97
    4 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 165
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 14.20 V
    ON
    ON
    OFF
    OFF
    OFF
    00906 - Horn (H1)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.85 V
    OFF
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.80 V
    OFF
    ON
    OFF
    OFF
    OFF
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 14
    Reset counter: 128
    Mileage: 153281 km
    Time Indication: 0
    Freeze Frame:
    OFF
    Voltage: 9.80 V
    OFF
    ON
    OFF
    OFF
    OFF
  9. Re: vcds help
    134 Post(s)
    2016 Post(s)
    That’s I one we don’t see here, a natural gas and petrol model with a BSX engine.
    Anyway I think you should do as been suggested and try the horn, wipers and indicator using the central electrics output function.
  10. Re: vcds help
    Ireland
    A poor battery might be causing the majority of the faults.
    I would replace this firstly if you are finding that it is discharging easily.
    Turn your ignition on and run the output test on 09. See does your horn work and your wipers through all the stages.
    Just follow attached
    15 535d 313bhp
    VCDS HEX V2
  1. A6 C6 VCDS Changes - Post & Pre Facelift
    By MFGF in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 10-11-2022, 09:33 PM
  2. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  3. Did VCDS caused a stereo fault?
    By Axios in forum VCDS - Help Requests
    Last Post: 16-12-2010, 01:17 PM
  4. VCDS OR VAG CAN Commander
    By Tariq Malik in forum VCDS - Help Requests
    Last Post: 12-03-2010, 03:02 PM
