Thread: mk2 golf gti fuel pump
Results 1 to 10 of 17
  1. mk2 golf gti fuel pump
    Jun 2008
    hi there, i have a mk2 1.8 k-jet golf 1987 i recently did abit of wrk on it and now it will not start, i believe it to be the relay for the pump as i have done the volt test on the contacts as the haynes manual told, but i got 1 wrong reading across the 5-1 contacts, does any1 know wat this means ? is it something more than just the relay ? and if not does any 1 know if i were to hard wire the pump through a switch would it permanently be on and would this do any harm ?
    regards
    sean
  2. Angry Re: mk2 golf gti fuel pump
    Jun 2008
    well to answer my own question - i replaced the relay with no success still will NOT START. the only other things that it could possibly be is either wiring somewhere in the harness or the hall sender unit... does anyone have experience with this unit and is it most likely to be the cause of all my trouble ??? rather than a some pesky wiring somewhere.
    cheers
    seanw
  3. Re: mk2 golf gti fuel pump
    2022 Post(s)
    Firstly you must not run the pump by a switch, the relay is there to cut the fuel in the event of an accident and the engine stopping, bodging this could be fatal…
    If you look at the relay you will see there are two large contacts. Look at the fuse box to where these terminals correspond and use a wire to jump across the points on the fuse box, the fuel pump should run
  4. Unhappy Re: mk2 golf gti fuel pump
    Jun 2008
    i tried jumping the terminals 2 and 3 ( the large 1s) and nothing, i have also done the checks haynes mention for the terminals, 2 - grnd, 2-1,4-1 and terminals 5-1 all come back the same. i have also switched the relay with a new 1 and replaced the fuse box with another. all wiring has been checked for continuity and all comes back ok. aswell as this the pump has been hooked up to a battery to check that it works and it does. due to it being a k-jet engine it has no ecu...... so what could it be lol its VERY annoying
    regards
    seanw
  5. Re: mk2 golf gti fuel pump
    Jun 2008
    i have also just carried out a continuity check on the harness for the ignition module and have found that the wiring to the hall sender unit comes back giving no readings at all. could this be the problem ?
    cheers
    seanw
  6. Re: mk2 golf gti fuel pump
    Jun 2008
    lol im talkin 2 myself here... correction on above, after a bit of fidling (remembering to reconnect the yellow/red wire XD ) the bridge did in fact work and the pump worked. so does that mean its the controll module or sumthing else which is stopping the pump from priming and working upon starting ??
    cheers
    seanw
  1. Golf GT 7DSG review after 6,500 miles
    By slo007 in forum Golf MK6 - 2009 - 2013
    Last Post: 14-11-2010, 12:05 PM
  2. How To: Convert Mk5 Golf Front End to GTI, GT or Jetta
    By goofer101 in forum Golf MK5 - 2004 - 2009
    Last Post: 01-07-2009, 04:45 PM
  3. Mk2 Golf Gti not starting
    By KarlosGti in forum Golf MK2 - 1984 - 1992
    Last Post: 20-10-2007, 02:28 PM
  4. Golf 1.4 TSI
    By bora(ing) nick in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-04-2007, 04:59 PM
