Thread: Rear LED Lights Retrofit Problem
  1. Rear LED Lights Retrofit Problem
    Jul 2007
    I have a problem with my rear LED light's which were purchased from an audi dealer and fitted a couple of years ago.
    i dont know how long this problem has been going on for, but i think it may have got mixed up with another problem.
    with the ignition on and the lights switched off, i get the following flashing sequence from my rear lights every 20 secs or so.
    1) RH outer and RH inner together
    2) RH inner
    5 sec pause
    3) LH out and LH inner together
    4) LH inner
    with the ignition on and the lights switched on there is no flashing of lights observed
    in recent months the outer left rear light has let water ingress, and i beleived this was causing the problem. however, this light has been dried out a couple of times and sealed, but the problem still exists.
    any ideas appreciated
    f792
  2. Re: Rear LED Lights Retrofit Problem
    Nov 2010
    Reading
    This is a long shot but, who fitted them? If is was not Audi did they code the car? It needs to be set to Highline for them to work correctly.
  1. Rear Lights, Backward Step?
    By logiclee in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 14-03-2011, 02:11 PM
  2. LED rear lights standard on GTD?
    By ac606 in forum Golf MK6 - 2009 - 2013
    Last Post: 19-10-2010, 01:01 PM
  3. Please Help No Rear Side Lights
    By threetone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-10-2010, 08:29 AM
  4. Bentley announces detailed specification of new mulsanne
    Last Post: 02-03-2010, 08:11 PM
  5. Rear lights on 1995 ford escort!!
    By marcus in forum Chat - Anything with wheels
    Last Post: 21-09-2007, 02:11 PM
