Thread: Any comments on parking brake figures?
Results 1 to 10 of 14
  1. Any comments on parking brake figures?
    The beast had its taxi test with the council last week, and the parking brake Maximum Force figures were as follows:
    N/S 196 kgf
    O/S 220 kgf
    (Service:
    N/S 218 kgf
    O/S 261 kgf)
    Test Summary
    Pass value: 16% TW
    Test value: 25%
    Result: Passed
    However, I had it MOTd by my VW dealer a few days earlier, and although it passed the Advisory Notice included the following:
    Brake Advisories : RBT Park Brake Efficiency 16%
    Your vehicle has only just met the required parking brake efficiency. It would appear that the braking system requires adjustment or repair.
    Clearly there's a big discrepancy between the council's figures and the dealer's.
    So can anyone suggest why the discrepancy might arise and comment on the council's maximum force figures?
    Apart from the difference the reason I'm curious about this is that although the dealer included other advisory items on the invoice they didn't include the parking brake info, which is why I didn't notice it at the time. And since they replaced one of my rear calipers only a few weeks ago - and the other one at the last MOT - then they should be aware that it's maybe a sensitive subject for me, so I'm wondering if I should be smelling a rat, particularly with the supply issue for the replacement calipers.
    Unfortunately I don't have the NS/OS breakdown for the dealer's figures.
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  2. Re: Any comments on parking brake figures?
    Norfolk
    If those figures are for an epb, they are terrible. 25% is cr*p for an epb. You have something seriously wrong with the epb.
  3. Re: Any comments on parking brake figures?
    Correct me if i'am wrong,but from what i can make out of the test result is that the council's test, resulted in a 10% difference,and the service test resulted in a 16% difference,the allowed difference is 25%,so either way you are within the test value.The maximum braking values can differ depending on the settings of the brake tester
  4. Re: Any comments on parking brake figures?
    Quote Originally Posted by martin1810 View Post
    Thanks Martin. Any idea of what the figures should be on a Passat with the EPB working efficiently?
    Quote Originally Posted by kenney View Post
    Not sure if I understand your argument Kenney. I'm just kind of guessing, but I think the percentage figure is the total braking force compared to the car's weight, which is quoted as 1,690 kg.
    Thus 196 + 220 = 416 kg.
    416 is 25% of 1,690, rounded up. What you are on about is maybe what they call 'imbalance', which doesn't seem to be an issue.
    But the dealers figures were presumably around 270 kg (16% of 1,690 kg).
    And Martin thinks even the 416kg/25% figure is poor for an EPB!!
  5. Re: Any comments on parking brake figures?
    Norfolk
    I haven't got any figures handy but the epb is nearly as effective as the hydraulic system. So if you assume the hydraulics do 100% then you will get figures like 70% for the EPB.
    It is hard to imagine how your car ever produced such low figures, the system won't allow it without bringing up a fault. The only obvious thing would be very very groved/worn discs or pads.
  6. Re: Any comments on parking brake figures?
    yes it was imbalance i was refering to,but can someone explain,as i'am not familiar with the procedure,is 16% pass value the value which the vehicle will be approved with???????
  7. Re: Any comments on parking brake figures?
    Apr 2007
    France
    12 Post(s)
    fwiw, my French MoTs are: efficiency of handbrake: 21% for the Passat, 20% Laguna and MGB 23%! Clear as mud.
    That was three different MoT stations though.
    1996 Laguna 2.2D
    1977 MGB roadster
  8. Re: Any comments on parking brake figures?
    DSG4ME Guest
    Those figures, are they pedal figures of just the PB? the 196 etc ones, iirc that would swing the needle on the tester over to about 3 o'clock, which should indicate they are ok.
  9. Re: Any comments on parking brake figures?
    Norfolk
    My apologies for my earlier post which did not help. I should have read the figures more closely rather than just look at the percentage.
    I'll try again. Wheel brake action is given in kg per wheel. Tester usually tests 2 at a time.
    Brake efficiency is total wheel (kg) results divided by weight of car and expressed as a percentage.
    So if each wheel records 250 kg and the car has 4 wheels, the total is 1000kg. If the car weighs 1690 kg, the brake efficiency total is 1000/1690 x100%. which is 59%. The MOT limit is 50%, so 59% is a pass.
    Using the same figures the rear brakes would supply 250 + 250 = 500kg.
    500/1690 x 100% is about 30%. A typical cable handbrake may struggle to beat 20%
    but only needs to beat 16% to pass the MOT. So a good cable park brake on a 1690 kg car needs to beat 270 kg. (135 kg per wheel).
    Stuarts figures of 261 kg service and 220 park brake, show the park brake producing 84% of what the service brake can. A cable brake would not do this.
    So the park brake is functioning fine compared to the service brake. Without seeing figures for all 4 wheels it is impossible to comment further.
    God I hate long winded replies.
    2 0 0
  10. Re: Any comments on parking brake figures?
    DSG4ME Guest
    Yeah, but they're a better read though
  1. A6 Electronic Parking Brake
    By GLOVERGLOBAL in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2012, 11:19 AM
  2. Please Help Parking Brake Switch / Radio Code
    By fat controller in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-12-2010, 05:13 PM
  3. Please Help Fault in the Electronic Parking Brake !!!
    By yus786 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-11-2010, 04:31 PM
  4. Parking Brake Fault
    By dhanratty in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 15-11-2010, 11:41 PM
  5. Passat B6 resetting service light
    By gaz44 in forum VCDS - Help Requests
    Last Post: 20-05-2010, 07:22 PM
