Thread: diesel filter on 170 tdi
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
  1. diesel filter on 170 tdi
    Sep 2008
    hi al,
    can anyone tell me what colour the diesel inside the filter canister should be, i ask this because last weekend i thought i would take a look to see how dirty the fiter looked, the first thing that surprised me was the colour of the fuel, it was a bluey grey colour and the filter was jet black, anyone know if this normal or is it likley that there could be other issues that could cause this (tandem pump ?)
    any help much appreciated
    thanks again
  2. Re: diesel filter on 170 tdi
    Jan 2009
    towcester northants
    done loads that are jet black
    i believe its bleed back from the injectors
  3. Re: diesel filter on 170 tdi
    Norfolk
    The only way to look at the fuel is take some out in a glass so you can see it properly.
    It should look like the stuff from the petrol station pump.
  4. Re: diesel filter on 170 tdi
    134 Post(s)
    2012 Post(s)
    Tandem pump failure, I see it on about 10% of the ones I change filters on.
  5. Re: diesel filter on 170 tdi
    Sep 2008
    thanks guys
    is there a way of checking the tandem pump, i also get a misfire when accelerating hard (which was why i checked filter in first place) is it likley that the tandam is causing this due to contaminated fuel. thanks again
  6. Re: diesel filter on 170 tdi
    134 Post(s)
    2012 Post(s)
    If you have cross contamination it is likely that it is the tandem pump, it is virtually impossible to test for this other than by fitting a new pump and seeing if the contamination clears. Bear in mind the fuel tank is probably heavily contaminated.
  7. Re: diesel filter on 170 tdi
    DSG4ME Guest
    It will look blueish, take some and put it in a glass, a few hours later it will be gold with a small black residue in the bottom, if not it looks like you are burning the 505.01 as well.
    May 2007
    knee deep in clunge
    14 Post(s)
    Quote Originally Posted by toddy2008 View Post
    hi al,
    thanks again
    Soot content from combustion process returns in the fuel lines and therefore discolours the diesel
    Now this is not a problem unless it's excessive which indicates blow pass at the injector seats
    Oil will look like soot but if you fill a glass with your fuel sample and leave it for 24 hours then you should see separation of the soot content
    Tandem pumps are changed when they are not required and only if excess oil is present should you then check the pump as oil is a fuel and will cause no running issue unless excessive however soot will
    I would also replace the filter every 2 years or 20,000 miles
    Sent from my iPhone using
    My fat fingers
  9. Re: diesel filter on 170 tdi
    Sep 2008
    thanks again guys
    slightly conflicting thoughts regarding the tandem pump, dont want to spend £200 to find it don't solve the issue, but i will take a sample of fuel and let it settle.
    what would be the best place and method of obtaining the sample.
    should i syphon it from the tank or from the filter housing?
    thanks again
    colin
  10. Re: diesel filter on 170 tdi
    Norfolk
    Suck it out of the filter housing with a turkey baster thingy. I bet the fuel looks pretty clear in a glass.
  1. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
  2. Passat Petrol/Diesel?
    By damjee in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-04-2008, 10:26 PM
  3. 50mpg-plus Audi Diesel Sports Car Cleans Up In Geneva
    Last Post: 27-02-2008, 10:24 PM
  4. "How To" Change The Fuel Filter in a Mk4 Golf TDI
    By chris.fulton in forum Volkswagen
    Last Post: 06-02-2008, 05:43 PM
  5. New 2.7 TDI Model boosts Audi A6 Saloon range
    Last Post: 24-11-2004, 09:00 PM
