Thread: Passat B5.5 Remove / Refit Gear Knob/Gaiter
  1. Passat B5.5 Remove / Refit Gear Knob/Gaiter
    Jul 2007
    Kent, UK
    I bought a replacement leather gaiter for my B5.5 passat around 6 months ago. Numerous times i've thought "this can't be that hard"... pulled up the plastic surround and found I can't get the existing gaiter over the knob without removing the gear knob.
    Guess what... I can never figure out how to remove the gear knob!
    Any suggestions?
    Cheers,
    Apr 2007
    Lancashire
    This was covered elsewhere on this forum... try a search.
    Jul 2007
    Kent, UK
    Unless im missing a thread, I couldn't find any particular detailed/usefull instructions, just that it "clips off"... which is about as detailed as "remove the gear knob!"
    Oct 2005
    Gently squeeze the edges of the surround clipped into the centre console and pull it up over the knob (like taking a jumper off )
    Look at the underside of the knob and you'll see a clip holding the gaiter to the knob. Unfortunately you'll have cut the clip off.
    People use a small cable tie or something similar to reattach the gaiter.
    Jul 2007
    Kent, UK
    The clip looks very tough. Mine isn't plastic.. its metal. Time to get the sharp pliers out I think.
    Jul 2007
    Kent, UK
    and cheers... none of the other posts suggested I'd need a replacement solution to the metal clip!
    Jul 2007
    Chesterfield Area
    Any luck with re-attaching the gear knob?
    I find it hard to believe that a cable tie will do it. The current fixing seems very solid.
    Got a new gaiter on order.
  1. Replace Passat Gear Lever Gaiter 52 Reg
    By PeterGittings in forum Passat - Archive Topics
    Last Post: 21-06-2007, 05:35 PM
  2. Gear knob removal
    By CABBIE in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 24-05-2007, 01:57 PM
  3. Replacing Gear knob 02 Passat
    By lozza24 in forum Passat - Archive Topics
    Last Post: 28-11-2006, 09:28 AM
  4. changeing the gear knob gaitier
    By Z Man in forum Polo - Derby - Lupo - Fox
    Last Post: 04-02-2006, 02:01 PM
  5. taking off the gear knob
    By Z Man in forum Golf - Jetta - Vento - Bora - Archive Topics
