Thread: Intermittent tapping/clicking
  1. Intermittent tapping/clicking
    Feb 2010
    Burton Latimer Northamptonshire
    Sorry to bother you with this but any ideas would be much appreceated!
    The car is a 06 A6 Avant 2.7 TDI
    I am getting a strange intermittent clicking noise from the right-hand side of the engine bay. It follows a pattern of about 6 clicks and then it stops for about 2 seconds and carries on like that. It also continues a little bit after the ignition is turned off.
    The Emission warning light has also come on
    I have also recorded the fault and popped it on YouTube
    http://www.youtube.com/user/ZeeKlond.../0/eG4-GQFTk9U
    Any advice appreceated!!!!!
  2. Re: Intermittent tapping/clicking
    Please supply the engine code form the ID label in the spare wheel bay. You say RHS do you mean the drivers side or passenger side. Interesting the noise continues for several seconds after ir has been turned off as though it is associates to a run on device like the cooling fan. Have you tried detecting the source of the noise with a stetherscope or legth of windscreen washer pipe. Regards Peter
  3. Re: Intermittent tapping/clicking
    Long shot. Pull fuses S104 and S42 ( 40 Amp ) to disable the fans and try running the engine again. Regards Peter
  4. Re: Intermittent tapping/clicking
    I suspect this could be the Intake manifold flap motor 2 -V275- that has lost the plot, well the controller for it. Thre are two, one for each bank although the noise sounds more like a solenoid. Regards Peter
  5. Re: Intermittent tapping/clicking
    If you want a diagram of the layout and components under the bonnet then PM me or post up your email address. Regards Peter
  6. Re: Intermittent tapping/clicking
    Feb 2010
    Thanks for all of the advice!
    Ive tried the fuse's to no avail.
    I would agree it sounds more like a solenoid, looks like a trip no the local garage in the morning instead of work so i suppose every cloud.............
  1. Lots Of Faults
    By marf in forum A8 - S8 - V8
    Last Post: 23-03-2011, 10:50 PM
  2. Question Sorry not another CCM wiring question!
    By KieranM in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-01-2011, 06:15 PM
  3. Possible battery issue ??
    By Tay in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2010, 07:45 PM
  4. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
  5. Vag Results , Anyone want to quote me and repair?
    By pete2vinal in forum Golf MK4 - 1999 - 2004
    Last Post: 13-02-2008, 04:35 PM
