Thread: Tyre wear ?
Results 1 to 10 of 19
  1. Tyre wear ?
    Mar 2009
    Cotes d"Armor, France
    I dont think I'm complaining but:
    All 4 tyres seem to wear evenly. The last set were Michelin Pilot 235/45/17 and when I changed them they were all within 1mm of each other yet none had been swapped around.
    I changed the wheels for 16" and used Continental 205/60/16. That was 15k ago,
    I took it for MOT the other day and one of the rears had a cut that caused a test fail.
    I had a new one fitted and the fitter checked the other tyres and they were all about 4mm.
    He'd never come across this before.
    I've ran FWD cars for the last 20 years and have always had to change the fronts long before the rears.
    Have I got a problem or is this normal for Audi's
    Cheers Dave
    `05 1.9 TDI 130 Avant Multitronic - 4B5 06H - AVF HB9 Final Edition
  2. Re: Tyre wear ?
    You clearly drive with a light right foot. Simple. Regards| Peter
  3. Re: Tyre wear ?
    Mar 2009
    Quote Originally Posted by Peter D View Post
    Your absolutely correct with regard to the right foot but I have always been so. Thats why I dont understand why the Audi should be different to the Fords, Peugeot and Fiat I previously owned.
    I cant make my mind up if the fronts are wearing slowly or the rears fast.
    Yours confused
  4. Re: Tyre wear ?
    No you are gentle into islands and bends but then apply gentle throttle on exit. This gives a smooth ride but transfers weight to the rear and slightly increases the rear wear, thus balancing up the wear characteristics. I measured mine after you first post and I have less that a mm front to rear in diferrence in12K miles. Regards Peter
  5. Re: Tyre wear ?
    Jan 2006
    PRESTON, LANCS
    How much less than a mm pete ? could you be more precise ?.
    Unlike you to be so inaccurate
  6. Re: Tyre wear ?
    Mar 2009
    I'm glad I'm not alone with the tyre wear characteristics.
    My driving techniques are the result of early training. Try driving from Sheffield to Scarborough without using any brakes!
  7. Re: Tyre wear ?
    Just less than a mm, may be 0.9 mm. Depth gauges don't have decimal places.
    OP, Gentle braking is fine but beware of excessive disc corrosion particularly on the inside of the front discs. The standard for 16" rims, assuming they are 7Js would have 55 profile tyres. What engine do you have and what mpg do you get on one of your eco runs. Regards Peter
  8. Re: Tyre wear ?
    Mar 2009
    I have a Michelin Digital Tyre Pressure Gauge which gives 2 decimal places ... for what thats worth.
    205/60/16-69W
    2.5 TDI but I dont do eco runs ... its just ingrained in me from driver training.
    I get between 45-50 on a run though.
  9. Re: Tyre wear ?
    "I have a Michelin Digital Tyre Pressure Gauge " does it measure depth as well then and I think you will find it is one decimal place.
    A 60 profile tyre may give you a slight error on measure speed and distance, very small though. Regards Peter
  10. Re: Tyre wear ?
    Mar 2009
    Thats what happens to me when I try to do more than one thing at a time .. I meant Sealey - Digital Tyre Tread Depth Gauge
    I thought about that and I've found its a 2.5% error when checked using the SatNav so I correct my figures accordingly ... Are'nt I clever !
  1. Front Tyre Wear on Inner Edge
    By anthony_d in forum Golf MK6 - 2009 - 2013
    Last Post: 11-11-2010, 08:11 PM
  2. Strange tyre wear
    By wizbongre in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-06-2010, 08:32 AM
  3. Tracking / Tyre Wear - A4 1.9TDi 115PS Avant W registration
    By delta925 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-04-2010, 04:19 PM
  4. A4 Quattro Servicing Tasks
    By MrBeardy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-08-2007, 04:57 PM
  5. VW Passat Rear Brake & Tyre Wear
    By VWItaliano in forum Archive posts
    Last Post: 23-10-2006, 12:20 PM
