Thread: non starter
  1. non starter
    Mar 2011
    st silvain France
    Help please i have a mk 4 1.9tdi (engine code ALH ?)which refuses to start have tried all the normal stuff but then noticed that the engine pre heat (glow plug) light was not coming on at all even though its cold -2 last night. relay 103 is getting power but no power to the glow plugs!! I am new to VW but have a good knowledge of diesel engins any help or advice (tricks)would be
    great
    ps am in rual France and do not have any access to diagnostics
    Thanks in advance
    Chris
  2. Re: non starter
    Jan 2009
    towcester northants
    check the connector in plastic trunking behind battery as these can get corrosion in them if washer pipe has been off
    also check the base of the relay plate red/white wire on term 74 if no power there then relay plate reqd or wiring mod carried out to bypass
  3. Re: non starter
    Mar 2011
    st silvain France
    Thanks for the info
    Turned out that relay 109 was duff and not feeding 103 which was also not doing its thing , so between the two it was screwing up the whole thing
    both changed and now back too nomal
    Thanks again
    Chris
  1. touran starter motor problem & coolant loss
    By tambo in forum Touran - Sharan - Caravelle
    Last Post: 01-06-2015, 04:04 PM
  2. Question Starter issue?
    By nhi336 in forum Golf MK4 - 1999 - 2004
    Last Post: 23-10-2010, 10:47 PM
  3. sharan starter thimble help
    By rob5150 in forum Touran - Sharan - Caravelle
    Last Post: 08-06-2009, 10:19 PM
  4. Starter motor Audi 80 tdi 1z 90hp
    By motchy87 in forum 80 - 90
    Last Post: 30-04-2008, 01:19 PM
  5. Please help on removing a starter motor!
    By Wazza4 in forum Polo - Derby - Lupo - Fox
    Last Post: 25-04-2008, 08:22 PM
