Thread: Audi 2.0 tdi fuel injectors -measuring blocks
  1. Audi 2.0 tdi fuel injectors -measuring blocks
    Dec 2009
    Harlow UK
    Gents,
    I had my car (2007 Audi A6 2.0tdi BRE) scanned using an official VCDS system and in particular the measuring blocks for the fuel injectors and the results were as follows.
    Group 13 Idle stabalization (Injector Quantity Deviation)
    -3.01 mg/str cyl 1
    2.99 mg/str cyl 2
    2.99 mg/str cyl 3
    -3.01 mg/str cyl 4
    The car went belly up a few weeks ago and was diagnosed by Audi as Diesel leeking into the engine oil via the injector seal. This then took the turbo seals out so I have replaced the injector seals and fitted a new turbo but now the car is running extremely rough at tick over and need to know if these values point to injector trouble.
  2. Re: Audi 2.0 tdi fuel injectors -measuring blocks
    2009 Post(s)
    Those values are way way off, typically they would be no more than +/-0.50mg. Compression test first.
  1. Aluminium a5 coupe prototype shows the lighter side of audi
    Last Post: 04-10-2009, 02:16 PM
  2. Replies: 0
  3. Audi takes pole position in TDI diesel development
    Last Post: 01-04-2006, 07:34 PM
  4. New Audi A4 Cabriolet 2.0 TDI Ticks all the Boxes
    Last Post: 09-10-2005, 12:37 PM
