Thread: Lots Of Faults
Results 1 to 10 of 19
  1. Lots Of Faults
    Dec 2010
    brighton, uk
    hey all, one of my first posts so excuse me for banging on but here it goes.
    first of all after much hard work and saving i finally bought my first A8 back in december. i wanted specifically the D3 4.2TDI Sport in black. i found one 200 miles awway in coventry and lapped it up for £26.000.
    right now, after a few weeks driving i started to colate a list of faults that i clearly was unhappy with and wouldnt expect from a 3 year old car, heres the list :-
    rear lights led's blown
    boot release not working intermitant and auto open sluggish
    rear windscreen demist and radio interferance
    rear brake pads low (flashed up on way home)
    o/s rear door release not working
    oil leak
    oil burning on exhaust smell (after a faster drive)
    o/s headlight washer stuck out
    The Steering keeps going heavy on some turns
    There appears to be a coolant smell vapour coming from the undershield area on occasion.
    Key not in vehicle keeps flashing on the dash even when the key is next to me (fitted new remote battery and no change).
    The radio will not hold a station and keeps losing signal (NO AF)
    Satnav keeps freezing and resets
    Headlights condensation
    Gearbox thumps
    mirror fold in dosent work
    MMI dosent always pop up (have to reset)
    Accelerator hessitates and also feels like it sticks
    plus this list of fault codes from VCDS
    00956 - Key 2
    002 - Lower Limit Exceeded
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded – Intermittent
    01964 - Control Module for Seat & Steering Column Memory (J136)
    00065 - Left Rear Footwell Heater (Z42)
    01854 - Heated Seat; Right Front (Z46)
    011 - Open Circuit - Intermittent
    01856 - Temperature Sensor for Heated Seat; Right Front (G345)
    010 - Open or Short to Plus - Intermittent
    Tuesday,21,December,2010,17:34:48:50666
    VCDS Version: Release 10.6.3 (x64)
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Control Module Part Number: 4E0 910 279 Q HW: 4E2 955 113 C
    Component and/or Version: ILM Fahrer H15 0230
    Software Coding: 0143121
    Work Shop Code: WSC 02313 785 00200
    Additional Info: 4E2910113C Wischer WWS D3 H60 0440 4E0910557A REGENLICHTSENSORH13 0090
    VCID: 3669D4C138C1
    2 Faults Found:
    01520 - Rain and Light Recognition Sensor (G397)
    002 - Lower Limit Exceeded - Intermittent
    00908 - Control Module for Wiper Motor
    00664 - Fuel gauge
    01406 - No Flame
    01333 - Door Control Module; Rear Left (J388)
    Tuesday,21,December,2010,17:36:33:50666
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Control Module Part Number: 4E0 910 553 J HW: 4E0 907 553 F
    Component and/or Version: LUFTFDR.-CDC H06 6310
    Software Coding: 0015510
    VCID: 2A51F0B1FC79
    1 Fault Found:
    01398 - Signal Conductor for Central Locking; Doors Open
    01299 - Diagnostic Interface for Data Bus (J533)
    02268 - Switch to Deploy Display Unit
    007 - Short to Ground - Intermittent
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    02273 - Quiescent Current Stage 2
    02276 - Quiescent Current Stage 5
    02274 - Quiescent Current Stage 3
    02277 - Quiescent Current Stage 6
    lets go as far as to say i was not impressed at all. anyway, coventry audi took the car back for 2 weeks and fixed most of it, including fitting a new gearbox after finding water in there from a leaky cooler. ive now had the car back for 2 weeks and heres the new list including some faults still there
    Gearbox thuds in second gear
    headlights flickering
    MMI freezes in reverse camera mode change
    Gear lever release now badly clunks when you push the brake pedal
    Power steering loud hum thats intermitant
    so 2 days ago i took it to crawley audi my local dealer and said if it goes back to coventry then its staying there. because of this coventry decided to help and pay for 2 hours diagnostics at crawley which was nice i suppose (or the fact they would have had to reverse £26.000). ive picked it up today only to be told they cant find a problem but what they can find a problem with they cant seamt o find the cause to fix it. however they are supplying me with a new satnav disk lol
    so anyway, as i own 3 garages and am a mechanic ive decided to find the faults myself, any ideas anyone to help me out? and anyone got any clue why coventry and crawley have ruined my audi experience, atm i certainly wont be going back in 3 years for another A8
    jez
    Audi A8 4.2 TDI Quattro sport
    46 Post(s)
    Wow that is probably the most faults I've seen on a car in the time I've been here!
    I think the electrical pixies have decided to live in your car just like the corrosion pixies are living in mine
    Can't really give you advice as I'm not really mechanical minded but it sounds/looks like a total nightmare!!
    Hope it all works out in the end
  3. Re: Lots Of Faults
    Dec 2010
    brighton, uk
    thanks criss. yer a lot of faults and TBH i think ive missed a few. im so annoyed at audi, aswell as putting an extra 4000 miles on my car with travelling to and from coventry and also extended testing, i just feel like ive wasted my time and should have picked a crapper out of the paper. im very technically minded but im also old school, good with electrics and a piston etc so im gonna dig myself and then rip heads off after. if i cant diagnose within 2 weeks im gonna give the car back i think.
    whats happened with yours and corrosion? how old is it? my A8 is Ally and i thought the A6 was aswell?
    46 Post(s)
    If I were you I'd give the car back, honestly. It could turn out to be a future never ending money loss. Did you buy the car from Audi Coventry? Least they gave you a satnav disc lol.
    My A6 is only over 3 years old and has gained a spot of corrosion on the OSR door sill, it's only the size of a 10p piece but it seems it's blistered through the paint.
    Audi are taking it in next week to get repaired under the 12 year corrosion warranty so all is good I also noticed a tiny spot at the fuel cap last week and they are looking into that for me aswell. I always thought the A6 was aluminium aswell but obviously not where it's corroding.
    I take pity on you as a quality car shouldnt be deteriating like that at 3 years old. I would maybe expect it on an older, higher mileage car but not a young one.
    Good luck anyway!
  5. Re: Lots Of Faults
    Dec 2010
    brighton, uk
    Good luck anyway!
    im gonna give it 2 weeks for me to diagnose. however last night my shift release has suddenly decided to clonk louder .
    thats bad how you have rust already, do you live in salt? lol
  6. Re: Lots Of Faults
    Sep 2009
    NW England
    I wouldn't spend any more time or money on that car. Its inconceivable that it will go in for repair, then come out and be faultless for the next few years.
    I've had mine from 18months old to current 5 years old, and its worn out tyres, battery, a screen motor, thats about it. Which is what you'd expect from a quality car like an A8. There is something seriously wrong with yours that has caused so much damage across the car, just send it back and try again.
    Incidentally, the A6 is steel, and as a result it weighs more than the A8, despite its smaller size
  7. Re: Lots Of Faults
    Dec 2010
    brighton, uk
    Quote Originally Posted by Micha_elD View Post
    yer my thinking, but trying to find a same replacement isnt proving succesfull. i never knew the A6 was steel, good pointing.
    46 Post(s)
    You learn something new everyday! Thanks
  9. Re: Lots Of Faults
    Sep 2010
    manchester
    Hi Jez,
    Mate, that sounds like a nightmare. I too recently bought an A8 in November and started having eletrical problems with the 'coming /leaving home lights' staying on throughout the night, killing my battery!! anyway, took it to Lancaster Audi who having diagnosed it, said its the main Computer circuit located in the headlining (behind interior light)...Cost..approx £300 +!!! Luckily i know an electrical whizz, who was keen to open the unit to check - Turns out the unit has around 4 main plug connections going into it...seemed all fine, but then after inspecting closer, one of the plugs had not been completely 'plugged in over the snap-on connector...well done that...and hey presto..Problem Solved!!
    I would consult an 'Audi Specialist'... In my experience (ive got a BM too) ive dealt with specialists, and friends of mine who own several supercars will not use the main dealers - as they dont always have the know-how. Not to mention, these guys are Keen Mechanics. Well, after all, these guys love the cars they work on - unlike the dealerships, whom employ trainees, and allsorts etc.
    You'd be better off getting their advice, and if it is a an expensive fix - take it back to the garage, and threaten them with legal action - we've got so many fantastic 'buyer protection laws', we dont take advantage of.
    You cant buy an expensive item, and its got numourous faults, and having been 'repaired', its still got issues?? Look up on the net, theres probably a good few people that have had issues similar to yours?
    Anyway, i wish you the best of luck, as these cars are honestley Brilliant, and its just not nice when you spend a whole lot of dough on a car thats supposed to be oozing with refinement/luxury, but instead lighting up warning lights like a xmas tree!!
    LET US KNOW HOW U GET ON?
    SAF
    Dec 2005
    I'm going to hazard a guess and say that's been flood damaged.
  1. Help please - electrical woes after towbar fitting
    By dstanley in forum VCDS - Help Requests
    Last Post: 22-02-2011, 01:03 AM
  2. Possible battery issue ??
    By Tay in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-12-2010, 07:45 PM
  3. Engine Faults
    By blacksline in forum VCDS - General Questions
    Last Post: 28-10-2010, 11:33 PM
  4. 1st Locked out, now dead batt - plz help!
    By xouser8334 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2009, 03:25 PM
  5. passat 1996 lots off smoke when started
    By jill300268 in forum Early Passat Forum - Pre 97
    Last Post: 16-01-2008, 12:31 AM
