Thread: Where is the light sensor located?
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: Where is the light sensor located?
    BongoShaftsbury Guest
    Quote Originally Posted by Getaway_Driver View Post
    I might be wrong, but I think the Light Sensor and Rain Sensor are in the same unit in the rear view mirror connected to the windscreen - so I dont think you'll be able to "gaffer tape it", otherwise the auto wipers wont work.
    There is an option in MMI to turn DRL on (daytime running lights).
    I think if you want dipped beam headlights on all the time then you need to code that with VCDS - there was talk of it being possible by changing the country code.
    I can't find this setting in my MMI. Where is it on yours? Maybe it is for a different bulb configuration.
  2. Re: Where is the light sensor located?
    46 Post(s)
    Quote Originally Posted by BongoShaftsbury View Post
    I take it you have Halogen headlights in the car going on the fact you cant find the menu? Iirc, the Running light menu is only visible if you have Xenon headlights or if you have enabled the DRLs through vcds if you have the halogen setup.
  3. Re: Where is the light sensor located?
    The sensor G397 is part of the interior rear view mirror mounting assembly. The sensor deals with the auto lights and the auto wipers. The lighting is controlled by the onboard supply control unit J519 so I can only suggest you have the car coded to a country that uses DRL but be careful that that country does not have other changes that may effect you. Regards Peter
  4. Re: Where is the light sensor located?
    Jan 2010
    Yate UK
    17 Post(s)
    This isn't meant to sound sarcastic but I fear it might...
    Is it too much effort to just turn them on when you get in and off when you get out?
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  3. ECU warning light and spurious misfire - electrical problem?
    By porterclough in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-03-2011, 10:14 AM
  4. Please Help A3 Sportsback '09 DPF Warning Light!
    By Foggie in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-10-2009, 12:48 PM
  5. Replies: 4
    Last Post: 18-08-2009, 06:47 PM
