Thread: Can I stop the seatbelt buzzer warning?
Results 1 to 10 of 10
  1. Can I stop the seatbelt buzzer warning?
    BongoShaftsbury Guest
    This buzzer drives me nuts. I do lots of short trips to move the car due to where we live and because its bonging all the time (as I cant be bothered to belt up for a 30 second job) its having the effect of making me ignore all buzzers - mostly the important "you've left your lights on" buzzer.
    It doesn't even cease bonging when in reverse, when legally you are allowed to not have your belt on!
    So, whats the easiest way to stop it? Is there an easy short near the seatbelt buckle?
  2. Re: Can I stop the seatbelt buzzer warning?
    You will need VCDS and see:
    http://wiki.ross-tech.com/wiki/index...%29#Adaptation
    For Model year upto 2008.
  3. Re: Can I stop the seatbelt buzzer warning?
    Getaway_Driver Guest
    [QUOTE=BongoShaftsbury;623680]So, whats the easiest way to stop it? QUOTE]
    By putting your seatbelt on
    I don't think the airbags will deploy unless you have your seatbelt on either.
  4. Re: Can I stop the seatbelt buzzer warning?
    If these car movements are in a public place or a road deemed to be a highway then the other bonging noise could by the BIB at your door bell to issue a FPN for not wearing a seat belt. Regards Peter
  5. Re: Can I stop the seatbelt buzzer warning?
    Nov 2010
    Reading
    I have found without your seatbelt on you have to press the brake pedal to release the handbrake when setting off forwards (manual car). With your seatbelt on it auto deactivates.
  6. Re: Can I stop the seatbelt buzzer warning?
    Quote Originally Posted by singhl View Post
    Singhl, what's the basic requirements for VCDS in terms of software/hardware?
  7. Re: Can I stop the seatbelt buzzer warning?
    here, but wish I was there
    You could just buckle up the seat belt before you get in, then sit down on top of the belt......
    Or on eBay for about a fiver you can buy what is in effect the seat belt buckle on it's own, clip it in and hey presto it thinks you have put your seat belt on.
    On my A6 it doesn't go off until you exceed 15mph, I assume this is normal ?
    Current - 2002 Audi A6 2.5TDi Avant quattro (loved), 2012 Ford S Max 2.2 tdci Titanium X (serves a purpose), 1983 VW Golf GTI campaign (loved)
    Previous - 2007 Volvo XC90 D5 SE Lux (gone, hated), 2002 Audi A3 1.9TDi Sport quattro (gone, liked and missed), 2011 Audi A6 2.0TDi SE (gone, loved and missed), 2007 Audi A6 2.0TDi SE (gone thankfully), 1999 Audi A6 2.5TDi quattro (gone, loved and missed)
  8. Re: Can I stop the seatbelt buzzer warning?
    You need what was called vagcom now called VCDS - for the a6 it needs to be the can bus version - i have this one - http://www.ross-tech.com/vag-com/hex-usb+can.html, make sure it has CAN bus, and you need a windows pc to run the software.
  9. Re: Can I stop the seatbelt buzzer warning?
    Lancaster UK
    An experiment this morning shows that if you get in your car and reverse it without wearing a seatbelt no alarm sounds. If you then drive forwards the alarm sounds for around 90seconds before it automatically stops.
  10. Re: Can I stop the seatbelt buzzer warning?
    Oct 2010
    Berkshire, UK
    Quote Originally Posted by BongoShaftsbury View Post
    My understanding is that if you remove the option with VCDS, you also lose the flashing signal in the dashboard. There is no way of just removing the chime or adjusting its volume.
  1. How To DIS AND CRUISE RETRO FIT b6+b7
  2. No seatbelt light or warning buzzer
    By Norman vwp in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-08-2009, 03:35 PM
  3. No seatbelt light or warning buzzer
    By Norman vwp in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-08-2009, 06:45 AM
  4. Headlamp warning buzzer failure
    By Arthur Haynes in forum Arosa
    Last Post: 27-03-2008, 09:10 PM
  5. Stop Warning Light In Dash
    By Passatguy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-11-2007, 09:23 AM
