Thread: Drinks too much diesel :( Lambda/Oxygen Sensor)
Results 1 to 10 of 10
  1. Drinks too much diesel :( Lambda/Oxygen Sensor)
    Jul 2008
    Bristol
    My Passat has been drinking alot of diesel, in the past few months. I took it to the garage and they told me that I need to replace the Lambda Sensor, as this is causing the problem. In the morning, I always get a EML sign, and Emission garage! on the dash.
    Could it be something else?
    There is a slight misfire on 1st and 2nd gear, just below 2000rpm only for a few seconds. ECP are pricing their sensor for £116
    Is there any websites, that sell them cheaper? I looked on ebay but they are going for the same price
    For Sale: VW Passat 2.0 TDI Sport
  2. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Dec 2010
    Chester Cheshire
    Zeb, do diesels have a Lambda sensor, could be wrong but thought that was only on the petrol models.
    I had the same problem with mine shortly before the injectors failed
    What year and engine is it?
    Rich
  3. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Jul 2008
    Bristol
    Quote Originally Posted by richball65 View Post
    Rich
    Tbh I'm not too sure, all I was told that the Lambda Sensor is causing the problem.
    Year: 2005
    Engine: 2.0 TDI - BKP engine code
  4. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Dec 2010
    Chester Cheshire
    If you know someone or know of a local indy VW garage, or even your local dealer I would get them to diagnose the problem with VCDS. This will give them a fault code as to why the lights are on the dash. I would do this sooner rather than later as if it is the injectors when the completly fail the engine just shuts down and will not re-start. I speak from experience. Happend to me in the outside lane of the M57
    Sorry to be a profit of doom lol !
    There again it could be something simple !!
  5. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Jul 2008
    Bristol
    I will do that
    I do have the diagnostic kit, so I just delete it whenever it comes up. The code is usually 17519? I will check tomorrow to see what code it is.
  6. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    DSG4ME Guest
    Ok, first job, replace the coolant sensor, GSF is always cheaper, and what are your mpg figures?
  7. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Norfolk
    17519 P1111 Oxygen (Lambda) Sensor Regulation Bank 1, System too Lean
    Yes the 2.0 diesel does have a lambda sensor. You will have to replace it to see if it helps.
    DSG4ME..B6 doesn't have problems with coolant temp sensor because it is self aware. It will flag a code if the coolant sensor is out of spec. Not like on the old models.
  8. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Jul 2008
    Bristol
    The code is 17519. I will look into this, and find out where I can the sensor slightly cheaper.
    I filled her up by 7 litres last night, I drove 6.7 miles and was getting 30.6 mpg in the city. On the motorway I was getting around 40.6mpg. Diesel miles showed 145 miles/distance I can travel, the needle was on the 1/4 mark. Within those miles the distance/miles went lower and was showing 120! The needle dropped by another 1/4 of diesel.
    This just doesn't seem right, plus the slight misfire which only happens in 1st and 2nd gear.
  9. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    North East England
    The only reliable way is to check mpg from a ful tank to tank (even part top up) but 7 litres here and there wont really give you a reliable indication - what does it normally show on the mfd?
    could it be MAF or EGR related stuff?
    2010 Audi A4 avant s-line special edition multitronic
    2003 Lotus Elise Type 49 - current
    2008 Passat Bluemotion Estate 105bhp of eco power - gone
    2007 Audi A4 Avant S-Line Special Edition - gone :
  10. Re: Drinks too much diesel :( Lambda/Oxygen Sensor)
    Jul 2008
    Bristol
    Quote Originally Posted by RicardoA4Sline View Post
    Yeah your right! In the city the mpg shows 33.6 - 35.5, and in the motorway it's 45.8 - 48.8mpg.
    If it was the EGR then the car will cough out alot of black smoke, the maf has been replaced by the previous owner.
  1. Replies: 21
    Last Post: 04-07-2012, 10:32 PM
  2. Diesel Fuel
    By Argonaut in forum Chat - Anything with wheels
    Last Post: 07-02-2011, 05:08 PM
  3. Question Location of the IAT (G42) and Boost Sensor (G31) Sensor
    By Poenie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 02-04-2010, 12:17 AM
  4. A4 Tdi B6 Engine Coolant Temperature sensor replacement
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2008, 10:58 PM
  5. Cruise Control cutting out
    By muleof1999 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-08-2007, 08:26 PM
