Thread: 80 2.0E (1995) Major overheating problem
Results 1 to 10 of 11
  1. 80 2.0E (1995) Major overheating problem
    Mar 2011
    Cornwall
    Hi, for the last few months i've had a real problem with overheating, its blown one head gasket and after replacing pretty much every component in the cooling system to have no joy and for the water to just boil out the expansion bottle.
    So far it has had:
    New rad,
    New expansion cap,
    New water pump (though has been stood for about 2 years since fitted),
    New stat,
    New cylinder head,
    If anyone has had the same problem? If so did you manage to sort it, and how?
    Seriously considering an engine swap right now
  2. Re: 80 2.0E (1995) Major overheating problem
    134 Post(s)
    2005 Post(s)
    Can you see coolant circulating?
  3. Re: 80 2.0E (1995) Major overheating problem
    Mar 2011
    Cornwall
    Not sure, there is water coming out the bleed screw for the heater matrix but not as much as it should and there is a lot of air coming out too.
  4. Re: 80 2.0E (1995) Major overheating problem
    134 Post(s)
    2005 Post(s)
    Take off the expansion tank return hose and rev the engine, you should get flow.
  5. Re: 80 2.0E (1995) Major overheating problem
    Mar 2011
    Cornwall
    Okay, i will try that once the water pump is back on
  6. Re: 80 2.0E (1995) Major overheating problem
    Feb 2011
    Derby
    Quote Originally Posted by Cadiddy View Post
    So far it has had:
    New rad,
    New expansion cap,
    New stat,
    New cylinder head,
    Just a thought, but have you renewed the cambelt? And are you certain that you got the dist drive pulley in exactly the right place? Because if it is just one tooth out, it will boil up like you are suggesting.
  7. Re: 80 2.0E (1995) Major overheating problem
    Mar 2011
    Cornwall
    Havent changed the cambelt but wouldnt you hear that the timings out?
  8. Re: 80 2.0E (1995) Major overheating problem
    Feb 2011
    Derby
    Not necessarily, my audi started and ran (albeit a bit off) but overheated like mad until I put timing right. Worth checking before major strip down.
  9. Re: 80 2.0E (1995) Major overheating problem
    Mar 2011
    Cornwall
    Quote Originally Posted by v8mick View Post
    How would the timing affect the cooling system? The cambelt has been off a few times and timed with the marks, could it be possible for the marks are out? Just to clarify, my dist you mean distributer right?
  10. Re: 80 2.0E (1995) Major overheating problem
    134 Post(s)
    2005 Post(s)
    If the valve or ignition timing are out either/both can cause it to overheat for various reasons too long winded to go into here.
  1. Steering Lock See Workshop and dealer problem
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 12-02-2020, 08:30 PM
  2. Please Help Audi 80 Auto Problem
    By googley in forum 80 - 90
    Last Post: 05-11-2010, 04:41 PM
  3. Audi 80 1.8s gearbox problem
    By bm50 in forum 80 - 90
    Last Post: 05-04-2009, 07:14 PM
  4. Please Help '95 Audi 80 2.0e Central locking problem
    By Nyxwolf in forum 80 - 90
    Last Post: 02-04-2009, 05:27 PM
  5. 95 Golf TDI Starting Problem Please Help
    By Millabit in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-07-2006, 10:55 AM
