Thread: ESP light flashing after changing wishbones
  1. ESP light flashing after changing wishbones
    Jun 2009
    Scotland
    Hi folks I'm hoping someone on here can help as I cant find the issue to my problem after using the search facility.
    problem is with my 2003 MK4 Golf GT TDI 130
    I changed both front suspension wishbones today, after taking it for a test drive the ESP light is flashing intermittantly.
    so I've fixed the clunking and created a new problem!!!
    So far I have checked both wheels spin fine (brakes arent binding), cant see anything obvious wrong.
    Tracking might need to be done as the steering wheel isnt centered now.
    The lower ball joint bolt does seem close to the driveshaft hub but there is a good couple of mm clearance all round and no rubbing/touching.
    any ideas on what I could have done / broke / need to look at next?
    any help appreciated!
    Edit: after reading other post brake lights can cause this???? I changed a rear tail light bulb last week, not had any probs since then until today with the ESP flashing is only after replacing the wishbones.
  2. Re: ESP light flashing after changing wishbones
    Jun 2009
    Scotland
    Fixed!!!
    Just in case this helps other in the future - the tracking was way out, once sorted the steering sensor stopped sending errors to the ESP.
  3. Re: ESP light flashing after changing wishbones
    Southampton, UK.
    Quote Originally Posted by recardo View Post
    Fixed!!!
    Nice one. Thanks for posting your fix!
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  1. Attention ESP Light
    By highliner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-11-2010, 06:57 PM
  2. battery light, flashing oil light, no rev counter....
    By Pickard1 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2010, 11:07 PM
  3. How To ABS + ESP + glow plug light flashing
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 05:56 PM
  4. Please Help Dashboard Cluster issues, rev counter, oil light and speedo
    By shaiboy_uk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-12-2009, 11:31 AM
  5. Water temp warning light flashing from cold - 98 Polo 1.4 auto
    By Scudetto in forum Polo - Derby - Lupo - Fox
    Last Post: 05-04-2009, 10:23 PM
