Thread: A 4 1.6 1997 ahl vag com code HELP please
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. A 4 1.6 1997 ahl vag com code HELP please
    Dec 2010
    northern ireland
    i bought a vag com cable with the software off ebay i did a scan and this is what it says please can you tell me if it is the lambda sensor or something else and does it mean the 2 faults are 1 been the brakes?
    thanks
    Address 01: Engine
    Controller: 3B0 907 557 A
    Component: 1,6l R4/2V SIMOS HS D02
    Coding: 04001
    Shop #: WSC 00000
    2 Faults Found:
    00537 - Lambda (Oxygen Sensor) Regulation
    19-10 - Lower Limit - Intermittent
    17978 - Shareware Version. To Decode all DTCs
    P1570 - 35-10 - Please Register/Activate - Intermittent
    Readiness: N/A
    Address 03: ABS Brakes
    Controller: 8E0 614 111
    Component: ABS 5.3 FRONT D11
    Coding: 0273004132
    Shop #: BB 24303
    No fault code found
  2. Exclamation Re: A 4 1.6 1997 ahl vag com code HELP please
    Dec 2010
    northern ireland
    ok now the car wont start !!!! only starts for 2-3 sec
    VCDS-Lite Version: Release 1.1
    Thursday, 03 March 2011, 22:10:16.
    Control Module Part Number: 4A0 953 234 F
    Component and/or Version: IMMO AUZ9Z0T9970259 D77
    Software Coding: 00000
    Work Shop Code: WSC 00899
    VCID: 253D7297ACEF
    1 Fault Found:
    01176 - Key
    07-00 - Signal too Low
  3. Re: A 4 1.6 1997 ahl vag com code HELP please
    131 Post(s)
    1979 Post(s)
    Check the chip has not fallen out inside the key and is rolling around. Open the key carefully, if the chip goes flying you are in the poo!
  4. Re: A 4 1.6 1997 ahl vag com code HELP please
    Dec 2010
    northern ireland
    there is no chip just the little transponder i have no remote locking just the 1 key ?
  5. Re: A 4 1.6 1997 ahl vag com code HELP please
    131 Post(s)
    1979 Post(s)
    Yes there is a chip, all cars built from 1995 have one. It is pressed into a little slot inside the y, or is that what you mean by the transponder?
  6. Re: A 4 1.6 1997 ahl vag com code HELP please
    Dec 2010
    northern ireland
    not sure the only thing i see in the key is what they call a transponder
    not sure if i can post a link with a pic here but its a small glass thing about the same size as a piece of rice
    http://www.audiclub.dk/content/graph...nsponder_1.jpg
  7. Re: A 4 1.6 1997 ahl vag com code HELP please
    131 Post(s)
    1979 Post(s)
    OK so the chip is there, you need a code read now.
  8. Re: A 4 1.6 1997 ahl vag com code HELP please
    Dec 2010
    northern ireland
    ok so how do i read the code ?can i use the vag com software and cable or do i need other software?
  9. Re: A 4 1.6 1997 ahl vag com code HELP please
    Jun 2010
    Lincoln, Lincolnshire
    i have the same problem, but it only occurs once a month or so. just turn the ignition just before the car starts an check for a little car with a key in it. This will mean that the immobiliser is still active if it flashes, and thus, the car will start for a few seconds an die off again. (very annoying when there are people around and they think your car wont start) so pull it out an try again. eventually it will give in an stop flashing. I find it is worse when you have had the engine off with the radio on for a while.
    But as said above you need to check the transponder chip. Also around the ignition there is an antenna you might want to check that too and replace/modify it
    Hope that helps
  10. Re: A 4 1.6 1997 ahl vag com code HELP please
    131 Post(s)
    1979 Post(s)
    Yes you can use VAG-COM, you need to code read the engine ECU and immobiliser.
  1. Please Help Fitted dis and cruise but having problems with coding etc
    By ukdan in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-07-2010, 06:45 PM
  2. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  3. Problems with Nav retrofit MMI A6 2008
    By craiglett in forum In Car Entertainment
    Last Post: 31-12-2009, 11:27 AM
  4. 2002 Passat Auto Window Closure VAG Com Code????
    By kiza132 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 17-03-2008, 01:19 PM
