Thread: estate boot release problem
  1. estate boot release problem
    Nov 2010
    leeds
    hi chaps, boot release has given up either from key fob or button on door any ideas please?
    cheers
    Steve
  2. Re: estate boot release problem
    Norfolk
    New lock required probably. You could investigate the wires in the tailgate. A VCDS read will tell if a fault is registered with the lock.
  3. Re: estate boot release problem
    Nov 2010
    leeds
    well tried a new lock and it wasn't that, put it on mates fault finder, nothing showed up so looks like I'll have to take it to a auto sparky, got me stumped (easily done) but thought it would be the lock as you have two ways of opening key fob and door button (wish they'd put a key hole in the door) any more ideas I;d be grateful
    cheers
    Steve
  4. Re: estate boot release problem
    Dec 2009
    14 Post(s)
    Not sure if it applies to the estate. But on the saloon you can open the boot from inside. I think its called the emergency release or something similar.
  5. Re: estate boot release problem
    Aug 2007
    Ware, Herts
    Quote Originally Posted by steve50 View Post
    Steve
    Do you hear a click when you try to open it? If it clicks then either adjustment (if that exists) or voltage not sufficient. This assumes the new lock was a good one. I have no experience of these locks but if there is no sound of a solenoid moving on either lock then its wiring or perhaps even a fuse. Is anything else not working? Sounds like a voltmeter may be handy.
  6. Re: estate boot release problem
    Obviously a different problem, but the switch on my tailgate started clicking on and off constantly one night a few weeks ago, and I had to disconnect the battery and leave it unlocked all night.
    My friendly VW dealer soon sorted it out though by replacing the switch, lightening my wallet by yet another Ł100
    06 Passat 2.0 TDi 140 SE Estate, Reflex Silver, 125,000 miles
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. estate boot release
    By robb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-02-2011, 07:39 PM
  3. Very Wierd Boot Latch Problem
    By Jamiem in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-12-2010, 11:21 PM
  4. broken boot handle on 80 estate (avant)
    By funkydunkscuba in forum 80 - 90
    Last Post: 13-04-2008, 11:10 PM
  5. New Škoda Fabia Estate Uk Pricing And Spec Is Announced
    Last Post: 03-12-2007, 08:08 PM
