Thread: Exhaust heat shield
  1. Exhaust heat shield
    Hi all,
    I need a replacement exhaust heatshield (the one that runs along the underside of the car). Not sure the best place to get such a thing? Any tips gratefully received!
    Golf Mk3 1.8 (8v) GL, 1994 ish.
    Cheers guys.
  2. Re: Exhaust heat shield
    Mar 2010
    Bristol UK
    Try a scrapper for heat shields or failing that you can buy stick on reflective foil (got some off ebay) if you're worried ...
    I wouldn't bother unless the part of the heat shield you need is over the cat or protects the fuel tank from exhaust pipe.
    My third stage shield (mid part), rattled like crazy (clips had rusted and some numpty mech had hammered the little posts flat ~ so it was impossible to just clip it back on), so I removed it and everything's fine (just keep moving) ...
    Actually I am looking for those little circular springy clips that vw uses to secure the shield and other stuff like the air deflectors/shields on the underside of the car (I will attach a pic of what I mean). I can't seem to find any anywhere (not even ebay) !
    If anyone has got 10 or so lying around, I would like to buy them
    cheers
    Matt
  3. Re: Exhaust heat shield
    Sep 2008
    Portsmouth, UK
    I used these small clips which are like a small rectangular piece of metal folded over on itself with a hole in it, these worked fine on the stubs protruding from the body when my heat shield came adrift.
    a bit like this:
    http://cgi.ebay.co.uk/6-X-MOTORBIKE-...item1c19db7062
    DKM
    Give me a chance to shine and i'll blind the world...
    2 0 0
  4. Re: Exhaust heat shield
    Cheers guys. I'm going to rip the bloody thing off and be done with it. At the moment our car sounds like one of those 'Just Married' affairs with a string of tin cans dragging along behind. Which does have its own humour of course..
  5. Re: Exhaust heat shield
    Lotus County
    Quote Originally Posted by mattymatt View Post
    cheers
    Matt
    These circular clips are available from VW (or Skoda) dealers and r very cheap - bout 16p each incl VAT. The hard part is getting under the car without a ramp or axle stands! However the m/cycle clips above seem more upto the job - if relatively expensive in comparision,,,,,,,
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Diesel Particulate Filter on Engine BMK
    By Leoflavio in forum Phaeton
    Last Post: 10-05-2010, 12:33 PM
  3. Rubber air con valve above exhaust heat shield
    By schiffcb in forum Touran - Sharan - Caravelle
    Last Post: 25-05-2009, 11:25 AM
  4. How To Need to replace Exhaust manifold Heat deflector plate
    By Ian Emms in forum Golf MK3 - 1993 - 1999
    Last Post: 29-04-2009, 10:30 AM
  5. Heat Shield above exhaust.....do you need it?
    By vw_craig in forum Golf MK3 - 1993 - 1999
    Last Post: 23-01-2008, 12:55 PM
