Thread: diesel warm start problems
Results 1 to 10 of 20
  1. diesel warm start problems
    Jun 2010
    Redhill, UK
    I have searched the forums & this seems to be a common issue, but I haven't found a definitive answer to it
    '98 1.9 SLX TDi with 120k
    starts fine when cold, but when starting warm - particularly when just slightly warm, & also when the engine has only been off for a few minutes - it cranks & cranks with noticeable shaking without starting. it does always eventually start, but it's a pain
    it has recently had a new battery & the problem bizarrely seems worse since
    any ideas much appreciated!
    thanks
    Andy
    I had a similar issue on a passat R reg.
    It turned out to be the temperature sensor.
    Have you checked for any fault codes. 
  3. Re: diesel warm start problems
    Jun 2010
    Redhill, UK
    sorry I haven't responded sooner, have been away all week
    I have a friend who is going to lend me a vag-com cable & I'll see whether I can get some error codes out of it
  4. Re: diesel warm start problems
    133 Post(s)
    1991 Post(s)
    This is a very common issue with this engine. You may find it has no fault codes stored. One solution we have found is to recode the ECU for automatic transmission. If this helps then a new starter motor often cures the fault which is down to the engine cranking over below the MAPS start threshold. Sometimes a new starter motor will not help. A diagnostic aid is to (once the codes have been read and saved) disconnect the coolant temperature sender when hot and see if this allows a quick hot start. If it does the problem (we have found) is in the ECU’s programing, the MAP so to speak and unless the software is re-written to fill a strange hole in the fuelling MAP at low RPM, you cannot cure this issue. Recently we had this issue afflict a 2000 Octavia TDI we fitted with a new engine. The only cure we could affect was to wire in a 5 pin relay with a resistor that was triggered by the starter motor. When cranking, this relay flicked over to the resistor which gave a reading of a cold engine and allowed the vehicle to start as it should but as soon as the starter was released, it flicks back to the sensors correct for temperature resistance. So far this has worked well and not given any fault codes. There is a propriety Italian made system that is plug and play for this solution and it costs about £150.
  5. Re: diesel warm start problems
    Hi there, this is really getting on my nerves, I have a Passat B6 1.9tdi, over 100K on the clock, recently it developed a problem, It won't start when the engine is hot. Cold start is good, starts at first click but after driving few miles and then if I stop the engine, it won't re start, but again it's not the case always, only some times. Because of this occasional problem I can't take it to garage and show them actually what is happening. Does anybody had the same problem? and sorted or anybody know why? please help.
    Thanks in Advance
  6. Re: diesel warm start problems
    Jun 2010
    Redhill, UK
  7. Re: diesel warm start problems
    Jun 2013
    worksop
    I have the same warm start issue, starts first time when cold but a short or long journey and it churns away for 5 secs before starting
    Golf mk5 04 reg 1.9 TDi
    AM i right in thinking if it was the mass air flow meter or enging temp sensor then it would show up on the fault codes ?
    because i have no fault codes
    so wondering if the relay will fix the issue ?
    Number 109 ECU Relay / Fuel Pump VW Audi Seat Skoda Diesel Meyle Germany | eBay
    Thanks John
  8. Re: diesel warm start problems
    133 Post(s)
    1991 Post(s)
    Good luck trying to fit that relay, that does not fit the Golf 5....People have become obsessed with this 109 relay crap, it can also be 30, 32, 460, 449 etc etc.
  9. Re: diesel warm start problems
    Aug 2011
    Meath
    Hi Crasher
    I have the same problem, do you remember what size resistor you used? thanks
  10. Re: diesel warm start problems
    133 Post(s)
    1991 Post(s)
    If you want to fool the ECU into thinking the engine is at around 20°c, something around 3kΩ
  1. Question Diesel starting problems, air in fuel line?
    By Hembrowr in forum Polo - Derby - Lupo - Fox
    Last Post: 08-03-2010, 12:58 PM
  2. Biodiesel - a summary
    By Huweth in forum Chat - Completely Off Topic
    Last Post: 06-01-2009, 06:25 PM
  3. problems starting A4 2.5 Diesel (Quattro, 03)
    By seanpcashman in forum Archive posts
    Last Post: 21-01-2008, 03:43 PM
  4. Passat X reg 1.8 petrol warm start problem
    By dtjvw in forum Passat - Archive Topics
    Last Post: 10-01-2007, 01:51 PM
