Thread: lt 35 ecu needs coding help
  1. lt 35 ecu needs coding help
    Mar 2010
    chester
    hi i have a 98 lt35 2.5 and i have recantly had the ecu re conditioned due to all kinds of faults but since it has come back it will only run for 2 seconds and cut out
    i had a mechanic come out and the only faults he could find
    p1612 engine ecu coding incorrect
    control unit coded wrong adaption limit exceeded
    i then contacted the people who reconned it they said yes just recode the ecu and it will be fine (unfortunatelly i have misplaced my wand) how the hell do i do this i can borrow a snap on modus computer will this do it
    any help or advice would great the van has been off the road since 23/12 so got to get it running its not even done 70k
    thenks neil
  2. Re: lt 35 ecu needs coding help
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Sounds like it needs coding to the Immobiliser. Thats possibly why it starts, runs then stops.
    Is it your vehicles ECU or a reconditioned one from another vehicle ?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: lt 35 ecu needs coding help
    Mar 2010
    chester
    it is the original ecu
  4. Re: lt 35 ecu needs coding help
    Mar 2010
    chester
    a bit more info that means nothing to me
    ecu id
    028906021 jk 1,91 r4
    edc 000ag 2019
    coding 00001
    wsc 014638 (poss 04638 poor writing)
    ecu type edc 9
    Oct 2010
    Here And There
    Starts for a few seconds and cuts out is your immobiliser. Have you a spare key to try ?
    I would get onto the company that done ( or done in, as it sounds ) the ECU and say " Nooo ! Not good enough !"
    Sent from my iPhone using Tapatalk as I forget how to use a full size keyboard !
  6. Re: lt 35 ecu needs coding help
    Mar 2010
    chester
    yes ive tried that all they say is that
    i asked why when it came off this vehicle would it need coding to this van
    Because obviously it is not synchronised, and there is a mismatch of information. It is not unusual for this sort of issue to happen once the ECU ha sbeen removed or battery has been disconnected.
    was there answer v unhappy
  1. 2011 CC VCDS autoscan anyone?
    By hartry in forum Passat CC
    Last Post: 03-12-2014, 03:45 PM
  2. yellow steering symbol diagnosis
    By pemac in forum VCDS - Help Requests
    Last Post: 27-04-2011, 10:22 AM
  3. Help please - electrical woes after towbar fitting
    By dstanley in forum VCDS - Help Requests
    Last Post: 22-02-2011, 01:03 AM
  4. Audi a8 2003 Current gearshift program problem
    By eints77 in forum VCDS - Help Requests
    Last Post: 20-07-2010, 02:58 PM
  5. A6 4F (C6) 2.7Tdi Avant, battery empty, fault log
    By luusje in forum VCDS - Help Requests
    Last Post: 05-05-2010, 06:45 PM
