Thread: Coolant Temperature Sensor Replacement Guide
  1. Coolant Temperature Sensor Replacement Guide
    A4 1.8t 2002 - rapid erractic readings on temp gauge for a while then no reading at all.
    (if you just have low readings that alter slowly then it's more likely to be the thermostat)
    Just thought I'd post this although I know it's been done before much more comprehensively with photos elsewhere on the forums - read them first and come back here if you're stuck.
    Problem I had is that my car appears to have more hoses, wiring etc getting in the way that most of the other guides I've read on the net, so I'm posting this for anyone that runs into similar problems.
    As we know the sensor is at the back of the engine and you can just see the wires coming off it if you look in from the side. Taking off what hoses, pipes etc you can that are in the way actually makes little or no difference, so don't bother! (I tried)
    IMPORTANT - only work on a cool engine and unscrew and then rescrew the radiator cap first.
    Shine a torch in and around from all angles first so that you get a really good idea of what you're up against. My first problem was that the handle of the little clip holding the sensor in was actually facing the engine and is impossible to get your fingers anywhere near and it wouldn't move around to the other side. I could see it through the wires and hoses from the top (it has little edges on it) so managed to pry it off with a long screwdriver - tried to avoid dropping it but it disappeared at the last second of course! (make sure you got at least one spare clip with the sensor you bought).
    It does feel like there's no way you can get your hands in at the back but you do have to kind of force them past the hoses and try different angles until you get in there - it is possible, just doesn't feel like it at first!
    You then wiggle the sensor and wiring holder around a bit until it comes loose with a pop - does feel like it's totally stuck fast at first.
    Bend the little plastic bit at the top of the wiring holder up a bit to allow you to remove the sensor and then insert the new one - it should click back in but mine wouldn't actually click so I will have to keep checking it's still firmly on every once in a while.
    The rubber ring may or may not have come off with the sensor, make sure you've removed it and put the new rubber ring in the hole making sure it's firmly seated. With the wiring attached to the new sensor put the whole thing back into the hole and try to ensure it's pushed in as far as it will go - it might seem to be a bit wobbly but try to look down and see or feel with your fingers if it's gone in far enough past the little slots at the side of the sensor holder pipe so that when you put the clip back in the inside edges of the clip will be on top of the sensor.
    TRICKY BIT - getting the clip back on. Fortunately it goes on from the bulkhead side towards the engine. Firstly get your hands comfortably in there as far as you can, pushing past any obstructions firmly (without doing damage of course). It's a tricky angle as you need to be pushing it in level but your fingers can only manage it at an angle. I first felt for the little slot on the left and made sure the clip was in there first and then pushed it down at the other side until it looked like it was about right - really take your time with this part, be very patient and relaxed!
    Push it in and then check and recheck as far as you can that it has located in the slots on each side - you can feel it with your finger tips rather than see it.
    Moment of truth - switch on engine and allow it to fully warm up, keeping an eye on the sensor for any coolant leaks.
    Such a pleasure to see the gauge reading half way again and just £8 for the sensor saved a fortune.
    It was probably more like half an hour rather than the 5 mins others talk about but it's done!
    Check for leaks on a daily basis at first, just in case the clip wasn't properly on.
    Good Luck!
  2. Re: Coolant Temperature Sensor Replacement Guide
    Jun 2008
    Beverley, east Yorkshire
    thanks for taking the time to do this, will help others in the future
    A4 AVANT 2.5TDI SPORT QUATTRO
  3. Re: Coolant Temperature Sensor Replacement Guide
    Aug 2007
    Newport, Wales
    7 Post(s)
    Thanks for sharing Mike.. I know it takes ages to do these write-ups.
    Can you possibly post the part number for the sensor and the clips.. if you still have them?
    I presume they'll be exactly the same parts for the 1.9 TDI (but I will check).
    The annoying thing is that it can apparently be the gauge on the binnacles that can be at fault.. but at £8 it's definitely worth a try... did you loose much coolant?
    Al.
    [ My Cars: 2011 Caravelle SE TDI LWB | 2015 A1 1.4 TFSI | 2017 Jag F-Type R 5.0 V8 Supercharged ]
    [ Past Audis:
    A6 S-Line 3.0
    V6 TDI Qttr | A4 3.0 TDI Qttr S-Line | S6 4.2 Qttr | A4 2.5 V6 TDI Qttr Sport | A4 1.9 TDI Qttr S-Line | A4 SE 2.0 TFSI Quattro Avant | 2.0 TFSI Roadster ]
    [ Past VWs: Mk1 GTI Cab | Mk3 2.0 Cab |
    Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI| Mk4 Supercharged 2.0 6-speed | VW Touran 2.0 TDI DSG ]
  4. Re: Coolant Temperature Sensor Replacement Guide
    Yes it can be the gauge but that's a big job and as the sensor does seem to be a very common failure it's definitely worth starting there first.
    VW AUDI GROUP PART NUMBER: 059919501A
    I just went for an eBay one - seems fine. Not sure if a link to ebay will work here so just search for COOLANT TEMPERATURE SENSOR AUDI A4 and it's the green one you want.
    Seems to be a standard part for all engines as far as I can tell.
    As long as you work on a cool engine and take off the coolant reservoir cap first and then fully screw it back on you only lose a really small amount of coolant. It barely shows any lower on the reservoir mark, so I've not even topped it up yet.
    Just be totally relaxed and patient when doing it - don't panic that you can't seem to get your hands in, as it does take a bit of fiddling them around. And keep a good grip on that clip when fitting it so that it doesn't ping off somewhere!
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. Please Help Do You have VCDS
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-01-2014, 11:17 AM
  3. 170 turbo from a golf into a passat
    By toddy2008 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-11-2010, 11:19 AM
  4. 1.8T Common Troubleshooting Guide
    By blacksline in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-11-2010, 12:17 AM
  5. Numerous Details on Digital Air Con Display
    By sooty in forum Chat - Anything with wheels
    Last Post: 21-01-2008, 08:09 AM
