Thread: B7 front Wheel Bearing Replacement
  1. B7 front Wheel Bearing Replacement
    Mar 2008
    Hi I am thinking of doing the front wheel bearings myself as I have access to a 50 ton press. Quick question does the lower arm need to be disconnected from the upright to get at the 4 retaining bolts for the hub? or can they be accessed by turning the steering on full lock? If anyone has got the instructions or diagrams would be appreciated. I just want to get fully prepeared before I do this. I did do a search and nothing on a B7 and on the B6 just said it was easy to remove
  2. Re: B7 front Wheel Bearing Replacement
    swindon uk
    Are you sure the wheel bearing needs doing?
    Reason i ask is that i thought i had a wheel bearing gone but then read some posts here about some tyres that can make the same droneing noise.
    When i changed my tyres, the noise went away.
    Something to think about.
    Audi A4 saloon, 2.0L tdi s-line. Retrofitted cruise control, DIS and MFSW. VCDS user.
  3. Re: B7 front Wheel Bearing Replacement
    Mar 2008
    Thanks for the advice but u have changed them and it is progressivly getting worse. If i load one side up the pitch also changes in the noise so pretty sure it is bearing. i have had the issue with the tread blocks on my Golf as well
    Oh well I am off to do the work this morning so will let everone know if y
  4. Re: B7 front Wheel Bearing Replacement
    Mar 2008
    Thanks for the advice but u have changed them and it is progressivly getting worse. If i load one side up the pitch also changes in the noise so pretty sure it is bearing. i have had the ytre issue with the tread blocks on my Golf as well
    Oh well I am off to do the work this morning so will let everyone know if you can do it without popping the balljoints.
  1. New bentley continental supersports convertible
    Last Post: 02-03-2010, 08:04 PM
  2. New bentley continental supersports convertible
  3. 4 Motion soft suspension
    By limecc in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-08-2009, 09:25 AM
  4. Greener New Generation Audi A3 Range Majors On Efficiency
    Last Post: 10-05-2008, 01:37 PM
  5. Mk3 Golf - Front Wheel Bearing Hub Torque Settings
    By BugBit in forum Golf MK3 - 1993 - 1999
    Last Post: 01-02-2008, 01:32 PM
