Thread: What's the plastic tube coming out of the battery?
  1. What's the plastic tube coming out of the battery?
    Dec 2010
    London, UK
    Hi, I'm an Audi newbie and I need some help.
    I need a new battery. The one in the car (brand: "Moll") has a small corrugated plastic tube coming out the side just underneath the + sign and it disappears into the ns wheelarch. What is it and do I need it? If so, does that restrict the range of batteries I can buy?
    Also, how is the battery fixed in place (i.e. where do I have to unclamp it)?
    2006 A4 Avant 140 S-Line (B7) 2.0 TDI BRE engine Dension Gateway 100 iPod cradle
  2. Re: What's the plastic tube coming out of the battery?
    Southern County Softy
    20 Post(s)
    The tube is a vent pipe, it stops the build up of gas, your new battery will have a hole to plug the pipe into.
    The clamp is at the front of the battery, if you ease the loom that runs in front of the battery and look down you'll see the clamp, think its a 7mm hex.
    A4 2.5 tdi QS (mapped)
  3. Re: What's the plastic tube coming out of the battery?
    131 Post(s)
    1973 Post(s)
    It also prevents the smell of the gases (Hydrogen Sulphide?) getting into the heater intake.
  4. Re: What's the plastic tube coming out of the battery?
    Dec 2010
    London, UK
    Brilliant - thanks for the quick replies guys. So I can just pull out the vent tube can I? (I don't like to pull at things unless I know what I'm doing).
    I notice I have lots of water swimming around under the battery. I guess the drain holes must be blocked - I assume that will be easy to do once I have the battery out?
  5. Re: What's the plastic tube coming out of the battery?
    20 Post(s)
    get rid of the water in the bulk by cleaning the drains, there is on on each side, under the battery and under the servo.
    Check your front pax footwell for damp !!!
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. Replies: 3
    Last Post: 21-08-2011, 10:01 PM
  3. Please Help 2.0 draining battery
    By volvofh in forum TT - TT RS - 8J Forum - 2006- 2014
    Last Post: 18-01-2011, 08:27 PM
  4. Changing battery on A4 B6
    By TheMatador in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-12-2010, 07:13 PM
  5. A4 Battery killer!
    By GeorgeFPA in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-10-2007, 01:07 PM
