Thread: Oil/fumes smell when turning on the heater
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Oil/fumes smell when turning on the heater
    I was afraid of that. If I were you I would drain and replace the filter and oil.
    Regards Peter
  2. Re: Oil/fumes smell when turning on the heater
    Jan 2010
    halifax, Emgland
    Thanks for your replies guy's.
    The oil drips on the ground ( a small patch) when parked overnight. Its definiately oil and not fuel.
    Was told to use this engine oil leak liquid. It does no harm to the engine so I have been told.
    The main thing is there is no smell of fumes anymore. just need to stop this little leak.
    I cant belive you say that its time for auction man..... Why would they produce these sort of oils/dye's etc to resolve these niggling issues.
    Are you serious that I need to drain the oil again ?
  3. Re: Oil/fumes smell when turning on the heater
    Yep get it out. Your next post could be that the front or rear crank oil seal has swollen up and has ripped itself apart and you have dumped all you engine oil on the road. Sorry. Regards Peter
  4. Re: Oil/fumes smell when turning on the heater
    Apr 2009
    Quote Originally Posted by dwight01 View Post
    LOL. I meant its used by unscrupulous people to get a car sold, not at
    your car.
    The inter-web is full of warnings against these oil additives..
    http://uk.answers.yahoo.com/question...0103138AAiktxQ
    'Smart' use of it would be to run it in an engine for about 40 miles and
    then drain it, hoping it would stop the leak without having done any
    harm. But that would only be for any hard-to-get-at oil seal, on a
    car that's not worth spending much money on, (again not yours!!)
    Regards
    Jim
  5. Re: Oil/fumes smell when turning on the heater
    Jan 2010
    halifax, Emgland
    LOL - Ok cool.
    Anyway problem sorted at last.
    Fiest it was the cover gasket to get rid of the fumes. The leaking oil was from the oil sump which has been fixed now. Oil flushed and put some new PD oil in from dealers. The guy also serviced it and cleaned engine with a cloth to get rid of some of the oil stains.
    ALl in cost £140 but problem has been sorted for both fumes and oil leak including a service.
    Thanks again for your input/advice guy's.
    Much Appreciated !!!
  1. heater, air con smell
    By rosieandjim in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-08-2010, 09:34 PM
  2. I can smell oil being burnt... what's the likely cause?
    By Niall76 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 17-01-2010, 09:00 PM
  3. burning oil smell coming in heater vents
    By caledonianewan in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2009, 11:52 PM
  4. Heater Blower Motor or something else?
    By Audi 80 Man in forum 80 - 90
    Last Post: 08-01-2008, 06:54 PM
  5. Heater core replacement 93 passat VR6
    By farmhemi in forum Passat - Archive Topics
    Last Post: 05-01-2008, 04:25 AM
