Thread: tdi hard to start, now no start
Results 1 to 10 of 13
  1. tdi hard to start, now no start
    Nov 2010
    doncaster
    hi everyone,
    was just wondering if anyone had any suggestions.
    i have read countless forums and threads on the hot start issue but mine is a little different and havent been able to find anything.
    the car is a 2001 passat tdi 130 pd (awx engine)
    bought the car 7 months ago and it has always had the hot start problem as in cranking for a while when it is at running temp (90 degrees) until it fires.
    changed the battery and starter as well as coolant temp sensor. nothing worked so i just lived with it.
    but now it wont start at all when it is at full running temp. it cranks well at 5-600rpm but will not fire at all, i am on my 3rd starter motor.
    like i said its only when its at 90 degrees.
    its starts perfect from cold everytime.
    even if i let it cool for 10mins so it drops from 90 it will fire straight away.
    any help appreciated as it keeps leaving me stranded, oh and no fault codes are being brought up
    1 1 0
  2. Re: tdi hard to start, now no start
    Jun 2006
    UK, Mids
    Have you checked for fault codes?
    I would check the coolant temperature signal to the ECU matches the coolant temperature sent to the gauge.
    I am wondering if you are getting cold start timing advance when you shouldn't.
    Audi A8 - 2015 - 3.0TDI
    1 1 0
  3. Re: tdi hard to start, now no start
    Nov 2010
    doncaster
    Its not bringing up any fault codes. The coolant sensor is new. Not sure what temp its reading tho.
    All dash lights are normal. It just wont start from running temp. Used to just take a bit of cranking til it fired.
    But now wont fire at all at running temp. Oh and it bumps start fine as well
    Cheers for reply
  4. Re: tdi hard to start, now no start
    Jun 2006
    UK, Mids
    You mean it bump starts when hot easier than it does with the starter motor?
    Is the crank speed low when hot?
  5. Angry Re: tdi hard to start, now no start
    Nov 2010
    doncaster
    It is cranking at about 600rpm when hot, so should be injecting fuel from what ive read. It just wont fire like its not getting fuel. When hot it just sits there at 600 rpm and wont do anything. But if i let it cool for 20 mins it fires right up. When it was being towed i bump started it fine. But this could of been because it had cooled a bit.
    Ive ruled out most things like
    Starter motor
    Battery
    Immobiliser (as its only wont fire at running temp)
    Coolant temp
    Im stuck now, was thinking fuel temp sensor but apparently that wouldnt affect starting.
  6. Re: tdi hard to start, now no start
    Norfolk
    An engine measuring block read when it is hot may give a clue to what is happening. A fuel temp sensor fault can make starting difficult. It depends what the coolant sensor is reading at the same time.
    1 1 0
  7. Smile Re: tdi hard to start, now no start
    Nov 2010
    doncaster
    Thanks.
    Just a bit of an update as i know a lot of people are having similar trouble. I have cured the problem of it cranking and no start. It was the wire to the fuel temp sensor had snapped.
    So anyone having similar trouble. The fuel temp sensor can prevent engine from firing when hot and it will just crank.
    Now its back to the hot start issue of it cranking a while before it fires when hot.
    Found if i disconnect the coolant sensor it fires right up. But the sensor is new so not sure what is causing that.
    Thanks 4 replies
    1 1 0
  8. Re: tdi hard to start, now no start
    Dec 2007
    wigan
    what do you call cranking a while mine turns over about 4 times when hot before it starts and straight away when cold..?
  9. Re: tdi hard to start, now no start
    Nov 2010
    doncaster
    mines the same as yours. cranks for about 6 seconds when at full temperature then straight away when not at full temp.
    found that disconnecting the coolant sensor cures this and it fires straight away when hot, so obviously temp related. its had a new sensor (green)
    but not a permanent fix as ecu thinks its cold all the time and injecting more fuel.
    cant think what is causing it now. been same since i bought it 6 months ago.
  10. Re: tdi hard to start, now no start
    Apr 2007
    midlands
    just a quick question have you tried starting the car with the clutch pedal pressed down ? had it a few times when duel mass flywheel has to much play in when hot so crank signal is all over the shop ?? just a thought
    1 1 0
  1. audi 3.0tdi engine measurement blocks
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 06-10-2016, 02:45 PM
  2. 2.5 TDI AYM engine Hard starting now wont start
    By westfield1962 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-09-2013, 10:25 AM
  3. Audi A4 Avant 2.0 TDI SE Start Problem
    By jcc1501 in forum 2.0T, TSI and TFSI - Engine
    Last Post: 17-10-2010, 02:42 AM
  4. Please Help Best Golf for £10k and confusion over different engines?
    By deshg in forum Golf MK5 - 2004 - 2009
    Last Post: 21-09-2010, 07:47 PM
  5. Please can someone help
    By Daz9048 in forum Golf MK5 - 2004 - 2009
    Last Post: 05-07-2009, 08:34 AM
