Thread: A6 drivers power window repair vid
Results 1 to 10 of 16
  1. A6 drivers power window repair vid
    Feb 2009
    Glasgow UK
    Hey all, as some of you may know I have been having problems with my drivers door window.
    The issue?
    It will go down via the drivers door switch but will NOT go back up this way, although it will go up to a full close using the "global close" feature.
    I'm no tech, but thsi to me suggests that the motor is ok and that there is another issue somewhere. I've heard of the plastic clips breaking?
    Anyhow, I've did a little research and foud this vid that looks quite helpful and wanted to share.
    http://www.youtube.com/watch?v=9UP1Rn7Wj3s
    Mine is going tothe dealer and will be replaced under warranty, but i thought it looked interesting and it may help someone else
  2. Re: A6 drivers power window repair vid
    Aug 2010
    Southampton
    Iam fairly new to both Audi cars and this forum. Links like this save £s which seems like a good idea when you own an Audi.
    Thankyou!
  3. Re: A6 drivers power window repair vid
    Feb 2009
    Glasgow UK
    Hmmmm..............now seem to have a similar issue again.
    The window will go down in one shot lowering mode if the button is pressed briefly and also up if the button is held .....but.....the one shot closing on the drivers door is inoperative?
    All the rest seem fine??
    More annoying than anything else...............need to do some research but not coming up with much........any ideas?
    TIA
  4. Re: A6 drivers power window repair vid
    Sep 2011
    Lurking over a keyboard ...
    There is a TSB with something similar to your description ... I'll PM you a link ...
    I had a sorta of similar issue and it was only the drivers side that it happened ... I just kept using the switch constantly and give the armrest a bit of a whack ...
  5. Re: A6 drivers power window repair vid
    Feb 2009
    Glasgow UK
    Thanks Gup, appreciate the time and effort to post this and also the pm sent / received a minute or so ago.
    I'll start by giving the arm rest a whack or two and see how that goes for me before I look into it further.....Thanks!
    Just checked your Thanks / likes..............I swear the forum is outta whack as you've only got something like 800+ thanks and 700+ likes, I know I've gave you at least that...lol
  6. Re: A6 drivers power window repair vid
    Aug 2013
    Embra
    I know this is an old thread but I have a similar issue with my driver's window - it goes down but up is random - sometimes it stops and then goes and then stops and goes down agai. I think the switch is bvggered and I have a new one but just thought I would check.
  7. Re: A6 drivers power window repair vid
    Nov 2009
    46 Post(s)
    I'm having the same issue on my A3, new switch required. A fault will also be logged regarding a defective switch pack.
    A couple of others have had to replace theirs, just pop the door card off.
  8. Re: A6 drivers power window repair vid
    Aug 2013
    Embra
    No fault codes, just out of control. Passenger window is also odd, goes down but not up.
  9. Re: A6 drivers power window repair vid
    Nov 2009
    46 Post(s)
    Does it work fine from the passenger side switch? If so, then just a new drivers master pack thing will be fine, only buy genuine, don't be tempted by the lower priced Chinese copies on eBay.
  10. Re: A6 drivers power window repair vid
    Feb 2009
    Glasgow UK
    Maybe I forgot to add, I had a replacement ( OEM ) drivers door master swithc replaced and all is noe once again as it should be
  1. Please Help CCM Issues (?) - Still none the wiser
    By SilentBob in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-02-2011, 03:53 PM
  2. Advanced new audi a6 travels light to tackle emissions
    Last Post: 11-12-2010, 07:22 PM
  3. Drivers side window stuck
    By dubluv in forum Golf MK4 - 1999 - 2004
    Last Post: 21-07-2010, 11:07 AM
  4. Drivers Window A6 Avant
    By alcapo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-04-2008, 04:14 PM
  5. The new Audi A6 Avant
