Thread: Check engine, rough start
  1. Check engine, rough start
    Feb 2011
    United Kingdom
    Question, I have a '06 Passat 2.0T. The check engine light came on. Took the car to the dealership. They said it was the lambda sensor. I changed the sensor. Check engine light came back on. So I changed the diverter valve. Check engine light came back on after 40 miles. Its not the gas cap either. The car runs fine, although there isnt quite as much power as there used to be.
    Also, occasionally after I refuel I have a hard time starting the car. Once it starts, it runs fine.....
  2. Re: Check engine, rough start
    Apr 2010
    Ashford, Middlesex
    Coil packs(s) maybe? Have you tried the simple stuff first - new spark plugs, air filter etc?
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  3. Re: Check engine, rough start
    Mar 2009
    York
    If you can feel the engine misfiring and sounding rough, together with the engine management light, it could be a coil (they are installed separately in the fsi engine). However, you'd certainly know it when driving as there wouldn't be 'quite as much power' there would be virtually no power!
    A3 8V S-Line Cabriolet 2.0 TDI
    Passat B6 FSI • Passat TDI 105 • BMW E90 318d • BMW F30 320d Lux
  4. Re: Check engine, rough start
    Norfolk
    Pointless guessing. Get a good code read from someone with VCDS.
  5. Re: Check engine, rough start
    Feb 2010
    bluntisham uk
    Had this on mine. It was the EGR valve. A good tech with the right diagnostic kit should be able to tell this straight away.
    Its an easy fit, just a couple of bolts and plug it in.
    The part was about £150.
  1. Diagnosis codes, 05 B7 2.0TFSIQ
    By grr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-12-2011, 04:01 PM
  2. EML comes on every few weeks with 3 errors
    By Dark Horse in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-06-2010, 07:37 PM
  3. Aaaaarh esp+engine light 1.6
    By jahilton2002 in forum Beetle 2000-
    Last Post: 20-08-2009, 10:47 AM
  4. Golf Mk3 2.0l wont start after engine swap
    By bluetack67 in forum Golf MK3 - 1993 - 1999
    Last Post: 05-08-2009, 07:47 PM
  5. 16 important OIL questions and answers
    By oilman in forum Archive posts
    Last Post: 25-01-2008, 12:49 AM
